Hi all, I'm coming to ask for help with my car. I've sunk 3k so far into trying to fix this issue but it still persists. Here are all the things I've had replaced by the mechanic.
I'm not sure if this is a contributing factor to the Spongy Brake, but I was told that the front axle is leaking on both sides.
Additionally, the car has a little over 463,000 mi.
The issue with the car is that when I brake, it doesn't feel responsive. The car slows down rather than being able to stop fast, if that makes sense. When you hold the pedal, it slowly sinks to the floor, especially when I'm braking.
I've posted in other numerous places, and they all suggest it has something to do with the ABS, but I get more opinions.
Thank you for your help.
- New Brake Master Cylinder
- New Brake Master Booster
- Adjusted Brake Master Booster
- Replaced RHS and LHS (Front) Calipers
- Replaced RHS and LHS (Front) Rotors
- Replaced RHS and LHS (Front) Brakepads
- Multiple Brake Fluid Flushes with visual inspection of lines. No rush or leaking, they are still good to go.
