176,000 miles.
Hey I am getting a leak (or 2) underneath engine - this is 2 years after headgasket and all that goes with that (PHH, rear heater bypass, new rad, shroud, fan clutch, fan, hoses including rad and vape system, too much to list) about 2 years ago - this is not even a daily driver - about 5K miles a year. Also went through exhaust and nearly 100% rear brake replacement including lines from the front.
History - when replacing head gasket I decided to go with full synthetic oil. I thought that was the time to do it. Around a year later, she started blowing blue smoke for a couple of weeks, but that passed. When it first occurred, I immediately went for an oil change, again to full synthetic, and everything calmed down. BTW, the oil cooler on the side of the engine was cleaned when I did the head gasket - just in case that matters.
Now I see drips here and there - not much, but still...... Could it be that the change to full synthetic cleaned/cleared out old oil stuck in places where it should stay to prevent leaks, and now I have these small leaks? If I go for another oil change BACK to regular oil, and do that, say, 2 or 3 times, each a week apart, do you think I might gunk up those leaks again and stop these annoying drips?
Also, any suggestions for a mechanic for my baby near Danville, VA - I want to do the front end major maintenance as suggested.
Thanks gals/guys,
Lucy
PS - she is rusty, but not that bad....
Thanks gals/guys,
Lucy
