- Year
- 1996
- Vehicle Model
- 80 Series
- Mileage
- 170000
- Color
- rgb(37, 93, 2)
UPDATED PRICE
1996 FZJ80 Rear ARB Locked
$19,500
170,xxx miles on the ticker
Not listed in mods:
Fresh wrapped leather steering wheel from Craft Customs installed 12-1-21
New windshield as of 1-27-23
Replaced as preventative maintenance for the new buyer within the last 100 miles;
New Distributor
All new window motors in all 4 doors
New interstate battery
New Starter
New Water Pump
New front window runs
New Windshield
Trucks is loaded with aftermarket parts and new OEM parts from Wits End, Cruiser Heaven, Cruiser Phil, and Cruiser Outfitters.
New fluids/baseline performed 5 years ago when I purchased the vehicle along with all new pads/rotors, heater hoses and heater valve. All parts/fluids have roughly 20.5k miles on them.
Regular oil and filter changes changes
I’m keeping the fridge, recovery boards and RotoPax.
All in all the truck runs like a top, is as mechanically sound as an FZJ80 can be, but needs some minor cosmetic attention. These cons are listed below the mods list.
Mods List:
Blue Hub fan clutch from Wits End
ARB dual air compressor
Weather Tech mats
Pioneer Double DIN
315/75/16 KM3 tires
4x4 Labs Rear Bumper w/dual swing outs
Smittybilt wireless Winch 10.5k H20
3/8” Synthetic Winch rope & fairlead
Wits End Rear QPM
Blue Sea components on QPM
Custom Front Bumper
Exhaust over frame w/magnaflow cat
1” Urethane Body lift
OME Coils
Photoman Alternator Bracket Kit
150 Amp Sequoia Alternator
Cruiser Phil Emu Wing Window
Rotopax
Uniden CB radio and firestik
Wagongear factory CB/FM mount
Land Cruiser Heaven Leather
Outer Window belt moulding
Aux fan wired into OEM auto temp switch
Icon Shocks with CDCV adjustable res
Wits End Castor correction plates
Plugs, Wires, ALL OEM heater hoses
Wits End EGR “keychain” plates
Huddexpo EGR “test” plug
MOOG u joints
Steer Shaft firewall gasket
Amazon Fridge
Wits End Extended Stainless Brake lines
Aluminum Sway bar extension blocks
LCP sway bar disconnects
Rad Rubber Fender Liners
HERE ARE THE CONS
*Cruise control works when it wants. From what I’ve read the cruise cable needs adjusting.
*The airbag light stays on (blinks a 5-2 pattern if I remember correctly?), I’ve tried the reset procedure once to no avail, you might have better luck.
*Front seats are 3 years old leather from Cruiser Heaven and look great overall. The driver side bottom leather was cut too big around the seat switch and looks like poop (My fault, it’s harder than it looks), and the passenger side seat back has 4 holes cut in it where it mounts to the seat frame (a friend thought a trim piece covered that).
*Truck has been buffed and looks great overall, but the hood clear coat is flaking
*Truck needs an alignment. Tires are wearing evenly but I replaced the TREs and the shop didn’t get the steering box and tires aligned correctly so it pulls ever so slightly to the left.
*Needs new vents registers.
*Could use new headlights. Inside housing are busted and can’t be adjusted. LED high beams are great, low beams not so much.
*The rear heater works but Is bypassed
*The EGR is deleted (I still have all the parts if you need to re install)
*Factory cats were replaced with a single magnaflow because they were clogged. Might effect you guys in strict SMOG state.
Located in Tuscaloosa Alabama.
$19,500
Not listed in mods:
New Distributor
New Starter
New Water Pump
New Windshield
Mods List:
Weather Tech mats
Pioneer Double DIN
315/75/16 KM3 tires
Wits End Rear QPM
Custom Front Bumper
OME Coils
Rotopax
MOOG u joints
Amazon Fridge
HERE ARE THE CONS
