Can't imagine bushings going from being okay to having sway just in the time to change shocks. Suppose one could fail completely but seems like that'd be easy to spot.
Did you run 35psi in the tires prior to the shocks? If I run mine that low the truck sways a bit on the highway. Usually go at least 40psi when I air up after a trail run and then go to 50psi when I get home to the big compressor. Have you tried a higher pressure to see if it makes any difference?
Is it possible the shocks are bad? If they sit the wrong way on the shelf too long the oil can leak past the seals and they won't work right even though they are "new".
