Mr Rockwell
- Thread starter
- #41
Just a sticker, but I may paint this on that snorkle.
Dang that is a LOT of air coming from the tank. Wow. Are none of the lines wet with fuel? No drips?Heres my bubble factory from the new filter assembly.
I chased down leaks as well and my primer pump was one of the culprits. In the meantime I replaced all the rubber lines and clamps for peace of mind. The standard equivalent to metric hose is close enough in my experience, if you just want to buy bulk hose. But finding where it's coming from as Darren said, is the first step.I suggest isolating from WHERE the air is coming from first. Move the clear hose.
If it is currently betwixt primer/filter and the injection pump, then move it to the primer pump and the hard line coming from the tank. If you don't see air then, you know it is the filter/housing. Reseat the filter or put on a new one. Still air, then change out the primer housing. They are still available and not too pricey.
If there is air coming fro the tank to the primer/filter housing, then start taking out the hard lines out from the filter housing back to the tank that are bolted to the body and frame.
Test each hard line with a vacuum pump to see if there are any leaks. Check all rubber hose components and clamps. Change any that are suspect and test.
Last case scenario if all lines text ok, drop the fuel tank, take out the pickup, and test those lines. I had a small leak in the pickup tube at the bend where it goes down into the tank.
I have the details I my build thread. Cheers, and good luck. None of this is terribly difficult., just messy and time consuming. Good luck! Stop by if you get really stuck and we can work on it together
Yeah, this is odd that a number of us all had this issue at the same time! Probably COVID related.Alright, no apparent leaks with soap and air applied to the fuel lines. Ordered some parts and dropped the fuel tank. I replaced all the fuel lines with new rubber and good clamps. I did my best to test the hard lines but I didnt get all of them. Got a new pickup because upon inspection, this one was rusted to hell and high on my list of suspects. The new one looked like the correct part and it went right in. I also bought a new fuel pipe assembly and a new fuel sender gizmo. I must have ordered the wrong parts. both are incorrect. the fuel pipe has a different thread for the fuel cap and a flaired neck on the pipe. The new fuel sender does not have the extra sensor stick. Heres a pic of the rusted pickup, fuel pipes, and senders. Should I just re-install the old pipe and sender unit? Is there anything else I should look at while the tank is dropped? I feel like I'm getting close to getting back on the road. It seems like there are a few of us with this problem.
