- Year
- 1995
- Vehicle Model
- 80 Series
- Location
- Boise, Idaho United States
- Mileage
- 206785
- Color
- green
I don’t really want to sell it and I don’t need to sell it but if somebody wants to give me $55,000 for it I will sell it.
The reason I would let it go (even for $55k) is because I have a 1995 HDJ80 I am building and the funds would really kick start that build.
I own a Land Cruiser specialty shop and this FZJ80 is my DD. All the work on the Cruiser has been performed by me. I have a massive file on the Cruiser with all parts receipts.
01/1995 FZJ80
6M1 - green
grey cloth interior
x3 locked
206,785 miles
This Cruiser originally came out of the Seattle area. As far as I know that is where it always lived. I got it about 3yrs ago, it sat for about the first year or so I owned it. It came to me with a bad engine which during tear down showed failed bottom end bearings. Everything I have done to the Cruiser has been done in the last year and 6,000 miles.
In February 2020 I decided to put it back on the road so I tore out the old engine, bought a new short block and started the build. I then bought a new bare head, cams and all valve related parts. I then built the new engine over last summer. I put the Cruiser back on the road September of 2020.
Like I say, it has a new engine not a rebuilt engine. I have dumped over $20k in parts into the engine alone. Rather than list all the parts I used how about I list what is not new in the engine bay. That would be intake and exhaust manifolds, distributor housing, upper and lower oil pans, the air box, IAC, MAF, throttle body and that is about it. Every other part in the engine bay is new including tons of OEM hardware. Not a single aftermarket part was used. This includes an OEM y-pipe and forward cat. New OEM wiring harness as well. It does have OTRAMM SS exhaust so I guess that is not an OEM part.
Oh ya, it does have a Mean Green starter and alternator so those are not OEM. It also got ARP head studs so it’s ready for some boost.
The engine has 6,000 miles on it now and has zero issues, zero leaks and runs like you would expect a new 1FZFE to run. Mobile1 full synthetic in it and only OEM filters used.
The front axle has been fully rebuilt. I put in new OEM 105 spindles when I rebuilt it and OEM drive flanges plus new lug studs.
Brakes fully rebuilt. It got DBA rotors and pads, remanned OEM calipers, SLEE SS brake lines, new OEM booster and master. Ebrake fully rebuilt including a new cable.
The steering is fully rebuilt. It got a RedHead box rebuild with 105 sector shaft. New tres and SLEE HD rods. An OME damper finishes it off. The column was rebuilt with new joints all the way to the rag joint in the drivers footwell. Fire wall column seal also replaced.
Suspension wise it got OME 861/862 coils and BP51 shocks. Dobinsons adjustable panhards. Sway bars rebuilt with OEM parts. Radius arms got OME caster bushes and new OEM bushes frame side. Caster is at 3.1*. Rear control arms got new OEM bushes. All new hardware in the suspension as well. I have added a 1” spacer to the rear because after adding some weight it sagged a little.
Fuel tank got drained, checked for rust/varnish (it’s perfect), new pump, new sending unit, new pickup screen, new fuel cap and new rubber fuel lines.
Tires are Yokohama M/T’s in the 315 variety, they have 2,000 miles on them at most. Wheels are stock but powder coated gun metal grey.
The Cruiser has White Knuckle sliders, a SLEE belly skid and a SLEE rear bumper. The stock under rad skid is a new OEM part.
Interior wise it has a Scangauge that I ran through the dash and located it at the bottom of the a-pillar. TuffDuck seat covers. JVC double din touch screen head unit. D light bulb replaced. 3D printed cup holders. New OEM drivers seat bottom cushion. New OEM drivers seat belt. 2nd & 3rd row seats are out but I have them. New OEM rear view mirror. One new overhead light. New door courtesy lights. New OEM drivers sun visor. The rear heater has been deleted and I used the correct OEM non-rear heater lines in the engine bay. Weathertech floor mats front and rear.
Body wise it got new window runs all around including new window squeegees. New rear hatch and tailgate weatherstripping. New door weatherstripping including the pinch weld ones. New tail lights and new front turn signals. New OEM outer mirrors. New OEM hood and rear hatch struts. Hood weather stripping and cowl too. New OEM wiper arms and blades all around.
There is even more done to the Cruiser I have not listed. Full build thread documenting everything can be seen here.
More or less I have done a full refresh on the Cruiser. It is ready to go, even on an around the world drive. No leaks anywhere, no issues, no codes, nothing. All fluids fresh, diffs and tcase changed twice in 6,000 miles. New plugs all around on diffs and tcase with allens on the drain plugs.
I have taken the Cruiser on ten or so wheeling and camping trips since putting it on the road last September. It has some trail rash or pin strips. There are a few little shopping mall dings across the body. The clear on the hood isn’t toast yet but it is hazing. The clear on the roof is failing in a few places. Zero rust anywhere on the body or chassis. I have drug it over some rocks so there are some trail rash on the sliders, rear bumper, axles and chassis. The muffler has one rock rash in it. I gouged up the rear driveline last trip out so it has a new OEM driveline going in next week. The carpet is not the best. The LHS rear fender flare has a few busted mounts. The OEM windshield has some rock chips and one small crack on the RHS.
I use this Cruiser, it is not a garage queen or shopping mall Cruiser. It is not a 1,000 mile time capsule but better than that it has a new engine just broke in and ready to go for another 300,000+ miles.
I have a few OEM parts I will include with the Cruiser. Such as the LHS rear fender flare. I am also willing to put a new windshield in it with OEM gasket for my full asking price. All parts used on this Cruiser are OEM unless otherwise stated above.
I can do additional upgrades on the Cruiser, at additional cost. Front bumper and winch, lights, drawers, you name it.
Price is $55,000 firm
Located in Boise, Idaho
Cheers
01/1995 FZJ80
6M1 - green
grey cloth interior
x3 locked
206,785 miles
Builds - 1993 refreshed (now gone) and 1995 build up with new OEM engine
I really have not done much with the 93 other than drive it the last three months. It is running absolutely killer though. The speedo input on the t-case was leaking a lot and had been for a number of years, big mess all around it. So I cleaned it up and re-sealed it. Zero leaks now. My alt...
forum.ih8mud.com
Cheers
