1995 80 series 1fzfe steering leak (1 Viewer)
West Aus
Okay leaking from what i think is the steering box please correct me with proper name and any possibly have a pdf manual for this one.
Power steering pump seems to be under and attached to refill bottle but nothing seems to be attached to belts so im thinking must be electric after market pump setup.
So have some power steering occasionally or all the time but not that great.
And i am thinking that the leak is out of where the steering gear goes into the steering box which is leaking.
Such a bad way to explain it but any help is graciously accepted once again.
Olathe, KS, USA
It's your PS hoses. The oil is on TOP of the gear, so it comes from above.
In your first pic, you can see the tear on the bottom of the hose at the metal joint where the hose meets the metal piece.
Replace the hoses.
Do ALL the RHD trucks have a remote PS pump? I've not seen that before.
West Aus
Replace the hoses.
First thing i will do then. I thought it may be a seal on top of the box.
In all honesty i have never seen this setup before. It seems to be an after market setup.
