- Location
- United States
Sold! No longer available. 1994 Toyota Land Cruiser FZJ80 $7,000 OBO
Just passed Colorado emissions. Clean title in hand. New head gasket installed by Slee Offroad in Golden about 1000 miles ago, and the engine was given a clean bill of health. The head gasket leak was diagnosed as a small leak and it never overheated. Regular oil changes. It has cloth seats, including the third row seats, all in good condition with no rips or tears. Locking Yakima cross bars and ski rack for 4 snowboards/skis on the roof. AC is icy cold, front and rear heat both work great. Tow hitch and 7 pin trailer plug.
I’d drive this one across the country tomorrow.
Major work listed at approximate mileage performed, receipts available:
Come by and take a look at it. We can adjust the price if you don’t want the Yakima bars and ski rack.
- 172,000 miles
- Full front axle service- new wheel bearings, new trunnion bearings, new gaskets, cleaned and repacked birfields are in excellent condition
- Differential fluids replaced front and rear
- New fuel filter
- Emissions system repairs: all new vacuum lines, EGR modulator and VSV, cleaned EGR passage, new intake manifold gaskets
- New PCV Valve, hose
- Brake fluid flush
- OME Medium springs and shocks for 2.5” lift
- Brake proportioning valve adjusted to accommodate lift
- Caster correction bushings installed with lift, caster inside factory specs 2.2º per side
- OME Steering stabilizer installed
- Air filter
- Five 255/85r16 Cooper Discoverer S/T Tires (about 33”), rotated on a five tire rotation (might as well use all five, right?) still in excellent shape with great traction in the snow and off road
- New hood and rear hatch struts
- Radiator flush, refill with Toyota Red Antifreeze
- New belts
- New matching OEM floor mats, all three rows
- 177,000 miles
- New heater control valve, new upper heater hoses
- Slee Offroad replaced lower heater hose, aka the “Pesky Heater Hose” and replaced distributor cap o-ring
- 180,000 miles
- New OEM starter
- 182,000 miles
- New front brake pads and rotors
- New OEM Oxygen sensors
- New OEM Mass Airflow Sensor
- 185,000 miles
- New Battery- higher capacity for better cold starting
- 189,000 miles
- New AC expansion valve, AC belt, (condenser inspected, cleaned, and is in good condition) and R134a refill
- Following work performed by Slee Offroad:
- New head gasket, head bolts, exhaust studs, all related gaskets washers, etc replaced
- Reconditioned fuel injectors installed
- Oil and antifreeze (Toyota Red) changed
- New OEM Plug Wires
- New OEM spark plugs, distributor cap, rotor
- New intake hose
