Trade 1994 FZJ80 "Norman" Trade for 60 or 100 (UPDATE: NOW HAVE OUTRIGHT PRICE!) (1 Viewer)
SOLDTRADE/FEELER:
I’ve had a 55, a 60, an 80 and now I am looking to potentially make a move. Some of you are probably familiar with my current rig, Norman (94 fzj80) or my previous rig, Ingrid (83 fj60) and are therefore familiar with how I build up my cruisers. So you know that my mods are purpose-driven and well thought-out.
Please feel free to re-direct to my build thread via the vehicle description in my sig. (Some pics below as well)
I WILL NOT DELIVER AND SHIPPING IS THE RESPONSIBILITY OF THE BUYER. KEEP IN MIND THAT I AM IN DURANGO, COLORADO AND SHIPPERS CHARGE A BIT MORE SINCE I AM OFF THE BEATEN PATH OF NORMAL EAST/WEST CORRIDORS. WHEN GETTING QUOTES FOR SHIPPING MENTION THIS FACT!, I RECOMMEND ERIC AT FIRST CALL AUTO HAUL. PLEASE READ THE DESCRIPTION CAREFULLY AND EXAMINE MY BUILD THREAD BEFORE MAKING AN OFFER. I WANT THE BUYER TO KNOW WHAT HE OR SHE IS BUYING AS THIS IS AN AS-IS SALE WITH "NO-BACK-SEES" THAT SAID, I WILL OBVIOUSLY ANSWER ANY QUESTIONS I CAN AND TAKE ANY PICTURES YOU MAY NEED.
1994 fzj80 – Norman – White – Blue Leather interior on mechanical seats
Engine:
217,000 Miles
Compression Numbers when purchased (PO) available in build thread – wet & dry
PHH and FHH – Silicone and constant torque (PHH bypassed all the way)
New OEM Power-steering pump and internal pump gear.
New OEM Cap, Rotor, Wires and plugs
New OEM Belts
New Rear heater hoses (OEM)
New SuperStart Battery
New Charcoal Canister (Rochester crossover)
Runs great, shows 71 EGR Code, O2 Sensors Checked, switching fine. Haven’t worried about it too much, I’m guessing mileage could be a little better.
Suspension:
OME 850’s (2.5” Heavies) up front with 5mm poly trim spacer and 1.5” MetalTech Spacers (Nice set-up to get to 4” while lowering bumpstops below the MT Spacer.
OME 863J’s in back (Lots of weight in the back so the J’s are nice)
OME 73L’s and 74L’s (Regular not Sport)
OME Steering Stabilizer
Slee Front Caster Plates (welded)
SS Braided Brake Lines and adjustment brackets
Front End Service was done by PO, one Birfield was replaced, one was not.
All New OEM Bushings on front Lower Control Arm
Front Sway Bar removed (still have it)
Slee Rear Sway Bar drop links
Slee Rear Bump Stop Drops
LANDTANK HD Rear Lower Control Arms
New OEM Bushings for LCA’s
Front and rear Ironman Adjustable Panhards
The only Control Arm bushings not replaced with OEM are upper Rears.
Drivetrain:
A442F Tranny shifts solidly, great shape (Flushed recently)
Transfercase operates perfectly (just a little driveline slop from auto locker)
Pin 7 and Center Diff Lock Switch Done
Rear Lockright Auto Locker
All New OEM U-joints
Driveshafts Phased and balanced
New Slee/Powerstop drilled and slotted Rotors
New EBC GreenStuff pads
New OEM E-Brake Shoes
Lucas Gear Oil (TC & Diffs done twice in my ownership, no water crossings)
New Neutral Safety Switch
New Rear Wheel Bearings and Outer Seals
Tires: 315/75/R16 First Gen. M/TR’s with 70-80% left and 2008 Date Codes
(The last batch before they were replaced with the 2nd Gen. M/TR’s)
Overdrive and ECT work properly
Extended Breather lines
Armor:
ARB Non-Winch Bull Bar – Steel Grey Powdercoat
Slee AC Dryer Skid – Steel Grey Powdercoat
MetalTech Sliders w/ Cat Protection – Steel Grey Powdercoat
Iron Pig Off Road Transfer Case Crossmember/Skid (The big one)
Iron Pig Offroad Rear Bumper with Single Swing Arm/Tire Carrier – Steel Gray PC
OEM Wheels Powdercoated to match the rest.
Cargo:
WagonGear Tailgate Storage Lid
Driverside Hanna Cargo Carrier
Custom PassengerSide 3rd row Airtank Rack/Holder
Yakima Towers and Load Bars
Interior:
Dealer Installed Unique Dark Blue Leather on Mechanical seats (best of both worlds)
Dealer Installed Blue Leather Accents on Door Panels
Non-USA Market Passenger Dash Grab on perfect dash
WheelSkins Leather Steering Wheel Cover
Dark Blue Sheepskins for the Front Seats (Front Seats could use new foam but are pretty good on the leather.
CruiserCrap TEQ Shifter for Transfercase
Rear Seat Leather is Factory Perfect
I have the Grey 3rd Row Seats in storage.
Sunroof works
Mid-Level Radioshack CB with Firestik Firefly Antenna
(Just enough Comms for CruiseMoab)
Radio Antenna works
I have most of the PO’s paperwork and all of mine.
Full Disclosure Cons/Problems from Front to Back
Front clip was less-than-exactingly repaired…Front radiator support should have been replaced after non-frame effecting accident that totaled it out. Therefore, the front fenders hang a little bit off, the inners are banged back into general compliance (light deformation, not giant) The driverside headlight assembly has intact glass but rigged mounting points (see build thread) and the passengerside headlight assembly has intact mounting points but a hole in the front glass contaminating the inside with condensation and dust. I have covered the hole with 4 or 5 layers of clear packing tape to stop further contamination but that red Moab dust gets in there somehow. The hood’s clear is coming off on the edges to an extensive degree and the hood has some hail damage. (replacement hood after accident). Basically the front clip (body) shows okay but has some issues. It’s what’s known as a 15 footer.
The vehicle's Air Conditioning stopped cooling once in Moab, during CruiseMoab 2011, after 5 hours of Slow-going and crawling on Hell’s Revenge and Fins & Things in 90º+ weather (AC on the whole time). This happens when the engine temp gets too high so I imagine a clutchfan fluid replacement and/or waterpump may be needed in the distant future. The gauge has never left the center but if the AC kicked off then it got over usual operating temp. (210º is the kick off?)
Windshield is cracked but not bad and has never gotten bigger during my ownership (Didn’t trust anyone local to seal it right so never did it)
Front Seats need new foam, outer bolster flattened on both Leather okay no rips.
CD player doesn’t work, I use cassette adapter and Ipod/Ipad or stream Pandora through my Crackberry
Small Bleach stain on lower carpet of driver second row door panel
Windows:
Driverside Front Window Motor replaced and powerful but tracks are slightly off so it doesn’t go up super smooth and it pops at the top instead of simply stopping
Passengerside Front Window is SLOW, tracks are good, will go in-op (will need hand assistance) if cold enough
Rear windows operate slightly faster than Passengerside Front but can also be rendered almost in-op by cold.
Some carpet stains in rear cargo.
Rear Seat Belt assemblies (3rd Row) removed (I have them)
Hood and Hatch supports become in-op due to cold
Aforementioned Code 71 EGR – needs deleting or repair. O2’s have been checked and are fine.
Rear Driverside Reverse Light (LED) is intermittent – connection suspected.
Small oil leak at Oil Pump Cover Gasket. Never hits the ground.
Small Leak at rear main or upper pan gasket. Never hits the ground.
Very small amount of rust on lower inner door skin of Driver side 1 and 2
Cosmetic damage to Land Cruiser trim piece on center of rear hatch.
Little bit of slop in the driveshafts that I attribute to the slop of an autolocker. The gears looked great when I put in the locker…and the pinion preload was still good.
Okay, that’s about all I can think of. May have forgotten something but I don’t think so. Please refer to my build thread for pictures and feel free to ask me for additional photos if needed.
A couple pics (some also available in build thread)
By trapper50cal at 2011-09-22
By trapper50cal at 2011-05-27
By trapper50cal at 2011-09-05
By trapper50cal at 2011-03-05
By trapper50cal at 2011-03-09
By trapper50cal at 2011-02-13
Less Stinkbug than this with the 850's and MT Spacers currently installed and the rear axle
sits further back due to the correction of the LANDTANK HD Lower Control Arms
By trapper50cal at 2010-10-27
By trapper50cal at 2010-10-02
By trapper50cal at 2010-08-02
And Norman is featured in THIS somewhat prominently:
Cruise Moab 2011 | Kokopelli Trail - YouTube
Cheers!
-Trap
Oh yeah, I'm sure...I wish I could win powerball and just have my 8 favorite cruisers in the stable...I have enjoyed the 80 the most, almost too easy to wheel in. I'm just really feeling the call to switch it up...happens every two or three years when I feel like my rig is complete.
You know, not to back track or anything but the more I read about A-Trac, the less undesirable it seems, So if anyone out there wants to offer a non-locked 100, I'll at least consider it....LX470's too.
Curious what you would sell it for straight up rather than a trade...if that is even an option.
If a mudder owned this:
Toyota : Land Cruiser Toyota : Land Cruiser | eBay
and had receipts of the timing belt and water pump at 90K
and the under carriage wasn't rusted (looks like it spent a lot of time in GA)...
it would be EXACTLY what I'm looking for...(assuming that as dealers, they have it priced a little high and would take $10.5K-$11K for it)
Where at in Colorado are you? I may be interested in doing a trade. I have a 99, 122k timing belt and pump done, rear locker, Ome 2.5", 285's with about 60% left.
Durango, but for the right truck, i'll go halfs on the travel.
Poncha Springs? Buena Vista? Google puts full trip at 434 miles.
By trapper50cal at 2012-02-11
Send me some pics: jwtravis@steamworksbrewing.com or post some up here...
that is a sweet rig! You should keep it.
Thanks Scrowley, believe me, it's hard anytime I think about changing cruisers, I tend to grow rather attached to them. The wife and I might be working on a rugrat pretty soon and I think a hundy might serve our purposes a little better along those lines...
PM'd "aphat426"...haven't heard anything since the tentative offer, so this is still on folks. Thanks for looking!
aphat426: check in man (if still interested), what you said you have to trade sounds right up my alley.
Okay, aphat426 decided to stay with his hundy...we are still a-go with this.
A lot of views on this thread...if you're looking and don't know if your 100 Series matches the requirements...post up!
I must of missed your outright sale price. It sounds like a great rig. I know these trades can be tough to pull off sometimes, but I'm sure something will work out...might just take some time!
GLWS!
Bump for a great rig and a better seller...wouldn't hesitate to do another deal with trapper ever. It was a great experience.
Hope you find what you are looking for man...upside for us is that we get to see you do another build on another platform!
Here's some more pics...
By trapper50cal at 2010-03-22
By trapper50cal at 2010-04-05
................................................(I replaced this plastic lever panel piece ^^^^)
By trapper50cal at 2011-02-05
By trapper50cal at 2011-02-28
Here's a Rooster Fish I caught in Puerta Vallarta...
By trapper50cal at 2011-02-23
Here's a shot of me deftly (luckily) avoiding bodysnatcher on Golden Spike
By trapper50cal at 2011-05-11
What the front seat looks like under the sheepskin
By trapper50cal at 2012-02-15
