- Location
- United States
1994 FZJ80 Landcruiser $8000
Tan with brown cloth interior, 205K, 2.5" lift, mechanically restored, no lockers
Pictures are posted online HERE.
Truck is located in East Texas. Call 903-504-1661.
I acquired this truck just over a year ago with the intention of building it into an offroad expedition vehicle. Plans have changed. I am moving out of the country, so it is time to sell my pride & joy.
The head gasket, radiator, and heater hoses (including PHH) were all replaced with new by previous owner. The truck has been extensively base-lined and all mechanical issues have been addressed by a top-notch Toyota mechanic less than a year ago. The truck runs and drives as new.
The following is a list of the work I have had done
• Resealed #1 oil pan and replaced #2 oil pan and drain plug
• Replaced oil with Mobil One and change filter
• Clean oil pump pickup screen and check oil pump
• Replaced oil pump O-ring and front crank seal
• Replaced belts while crank pulley off
• Replaced power steering pressure hose and replaced power steering pump mount O-ring
• Replaced valve cover gasket with tube seals
• Replaced distributor O-ring. Replaced cap, rotor, plug wires, and plugs
• Replaced fuel and air filters, flush F.I. system
• Resealed front knuckles, replaced inner axle seals, repacked pivot bearing, new wheel bearings, and axle joints
• Replaced gaskets and seals on knuckles, replaced brake rotors and pads
• Replaced rear brake rotors and pads
• Replaced right rear wheel bearing and seals to fix oil leak
• Bled/flushed complete brake system. Cleaned and adjusted parking brakes.
• Serviced auto transmission including R&R pan and cleaned and replaced pan gasket
• Serviced transfer case with correct 90W fluid and both differentials. Adjust transmission pressure cable.
• Replaced A/C compressor and clutch with factory Toyota reman units
• Replaced receiver/dryer. R&R evaporator case and replaced expansion valve and O-rings. Evacuate and charged system.
• Flushed cooling system and put in factory red Toyota coolant. Replaced radiator cap.
• Replaced starter with Toyota reman unit.
• Replaced battery terminal ends
• Tested alternator and battery. Checked okay.
• R&R catalytic converters, replaced leaking exhaust do-nut gaskets and some bolts & nuts.
• Installed OME 2.5 inch lift kit front and rear with springs, shocks, steering stabilizer shock. Also R&R both lower front control arms to install caster correction bushings for front axle. Checked and adjusted tow-in and alignment. Also adjusted steering gear box. (Lift kit: OME 851 coil springs on front and OME 860 coil springs on rear, nitro sport shocks, OME SD 24 damper, and OME CA 77B caster correction bushings)
• New strut supports for hood and rear hatch
• New antenna
• New matching tint on driver and passenger windows. Extra tint for rear hatch window included.
• Custom rear storage drawers installed
No rust, everything works, as it should, 3rd row seats are in storage and can be easily installed.
The bad: (This is the small stuff you can ignore or fix yourself)
• Small boo-boo on left rear quarter panel – patched and painted by previous owner – see pictures.
• Tires are good, but may need to be replaced in the next year or two
• “D” light on dash board burned out
• Turn signal wand returns a little fast on right turns. It’s fine on left turns. Signals work.
• New antenna
