When I turn my lights on I get no rear lights or brake lights. When I turn the lights off the brake lights work. I checked the fuse, the bulbs...any help would be greatly appreciated.
Another thing to check, is the trailer light supply box. Not sure if that’s actually what’s it’s called, it it’s on the driver side, wired in behind the rear bumper. Mine was messed up and causing all kinds of issues.
I would suggest starting at the front, tracing your way back to see where you have power...but it is likely it’s something in the drivers quarter panel.
Yup it’s so weird when the lights are off the brake lights work when I turn the lights on none of them workjust to confirm, is it only your tail/run/stop lights?
Thanks will check it outI had the same issue. The light bulb socket needed to be resoldered to the wire.
