For Sale 1994 6.0 LS Swapped FJ80 Land Cruiser
Year
1994
  1. 80 Series
Mileage
322000
Color
Green
94 FJ80 3X Locked Toyota Land Cruiser with LQ4 6.0 LS & freshly rebuilt 4L80E Transmission - Asking $18,000
Original Rust free Flordia Car,, I purchased the vehicle in Florida in 2020 with 285K miles. I Drove it home to my garage in the Chicago Suburbs which is where it currently sits. Put another 30K miles on the truck with adventures to Colorado and Utah with the toyota engine and trans. The truck never gave me issues but lacked power. Started the LS Swap Project in mid 2021 and got her running and driving in 2023. Purchased a used LQ4 6.0 LS and my mechanic tore it down to do a partial rebuild. I posted some photos. 4L80e Trans was freshly rebuilt with new trans lines installed. I've driven the truck with the LS engine and 4l80e trans for a little over 7K miles (322K on the odometer now). The only gauge that doesn't work is the tach, which is why I installed a Scan Guage. New parts on the build include:
  • Sloppy Stage 2 Cam
  • New Lifters and guide trays
  • All new gaskets
  • New wiring harness
  • New plugs and wires
  • All new accessories: AC comp, Alternator, Water Pump, Power Steering pump, Thermostat
  • New Low Profile Oil Pan
  • Marks 4WD Adapter
  • Custom Exhaust with twin magna flow mufflers.
  • Marlin Crawler: Crawl Gear in Transfer Case
  • New Stainless Steel Radiator
  • New Dual Elec Radiator Fan
  • New Optima Battery
  • Scan Gauge
  • New OME steering stabilizer
  • Marlin Crawler heavy duty front steering
  • Heavy duty front and rear adjustable track bars
  • OME Front and Rear shocks (2023)
  • Nitro Birfields (2022)
  • Double din Bluetooth radio (2021)
  • New interior Speaker (2002)
  • New lower seat cushions in front and new leather (2023)
  • New middle leather that still needs to be installed (comes with old middle seats which needs new lower cushions)
  • Newer seat belts (not yet installed)
  • New inner window trim/molding (not yet installed)
  • Rear Sway Bar drop
  • Front Sway bar drop (sway bar not installed for extra suspension travel)
  • Fresh AC Charge
  • New Depo Headlights with 2.5" honeycomb BI-LED projector lens RGB LED Angel Eyes and hot wheel shrouds
  • Newer Transfer case wiring harness
  • New Hella horns
  • 35" Nitto Trail Grapplers (2002 - some life left)
The vehicle runs and drives great with the fresh engine and trans. It finally has the power & acceleration this truck needs. It has every-bit of 400+HP.
Cosmetically it's not perfect but its a solid rust-free truck with a reliable and easy-to-work-on drive train. It has a raptor liner paint job that far from perfect. Car was originally dark green as seen in the door jams. I'm only selling the car because I moved out of state a few weeks ago and the vehicle is in my garage in Berwyn, IL.
Vehicle Flaws:
  • Slow windows
  • No Cruise control
  • Front Electric seat backs work but lowers need gears replaced & don't move
  • Not the greatest Raptor Liner paint job but body is rust free
  • Front Passenger Valve Stem needs replacing but still holds air
  • Vehicle needs alignment
  • Engine needs to be tuned
  • ABS is not functioning but most likely a sensor issue
  • Parking Brake not functioning
  • Middle seats not installed but they come with the vehicle as well as new leather for them
  • Tear in transfer case leather boot
  • Hi-Beam lights not installed
  • Needs a front bumper
  • Sunroof opens but needs help closing
  • Seat belts are ratty but come with a newer set to install
