- Location
- United States
Hello Guys!
I'm selling my 1993 80'..
This truck have been a dream to drive, own and built: Is time to get a house since my family is getting bigger.
I bought her BONE STOCK from a TOYOTA certified Mechanic.
Everything has been done by MY hands or qualified technicians.
EVERYTHING that you can possibly imagine on preventive maintenance was already done.
This is a 93’, a 23 YEAR OLD TRUCK. It does not look like it; it looks like a new truck. It does not drive like it, it drives like a dream. But you have to understand this; it is a 23 year old truck. It is NOT perfect but might be one of the best ones for sale right now.
I´m pretty sure I will not list ALL of the mods and maintenance because there are so many, but feel free to send me a message and will be more than happy to respond.
1. - 233.xxx miles (It is being driven, this will increase day by day, not more than 30miles are driven daily).
2. - OME J Springs front and back, 1” Slee spacer up front, OME steering dampener and FOX 2.0 SHOCKS.
-Slee Sway bar extensions.
-Extended Brake Lines.
-OME J Springs gives the 80 about 4” of lift. Right now it has 4” on the back and 3” on the front. ARB bumper and winch are heavy.
-The caster is corrected for 4” of Lift by bushings and drop brackets (TJM bushings and Custom made brackets). My plan was going a little bit higher on the lift. Will probably need stronger springs up front to stay at 4” lift. The caster is over corrected 1° due to the weight of the front.
-It gets heavier on the back with equipment and the roof top tent. So it seats even when loaded.
3. - 315/75/16 Copper STT PRO with less than 5000 miles on them. Still looks like new, balanced and rotated with every oil change. Eagle Rims.
4. - Engine light is on because of 02 sensors, the truck has NO catalytic converter. ABS was disconnected, for me, it handles better that way. No other codes
5. - Magnaflow Muffler
6. - Snorkel with high temperatures and more resistant hose.
7. - Dual batteries, Yellow top optima for cranking and Red top Optima for back up. OEM battery tray, OEM Battery holder, Slee windshield washer reservoir relocation bracket.
8. - Led light all the way around. In and out (not on turn signals). Even the cluster has been upgraded to white leds.
9. - Did you notice the paint job? Is freshhhhh! Around a year old. Everybody looks at it everywhere I go. Best color for an 80 series and it cost $6000.00 to get something like this done. Door Jambs and everything.
10. - Oil changed every 3000 miles. OEM filter and MOBIL SUPER 10/40.
11. - Transmission Fluid flushed 5000 miles ago.
12. - Front axle rebuilt around 3.000 miles ago. All OEM and Trail Safe Knuckle kit from Trail Gear.
13. - New Belts and AC pulley at 232.000 miles.
14. - Only premium gas used since I have own it. Gives around 11 mpg on the city and 14 mpg on the HW.
15. - I DO OFF ROAD THIS PRINCESS. I’m not going to lie like the other seller with fully built up 80 and saying “NEVER OFF ROADED”. Please, this thing is for that, to have fun and never worry about breaking something. Have NEVER let me down. NEVER.
16. - Cloth seats and upgraded leather door panel and arm rest.
17. - AC blows COLD AF.
You don’t see 80’s like this around. This thing has been babied since day one.
19. - Clean Tittle in hand.
20. - OEM Valve cover gasket, distributor, O ring, cap, wires and sparks plug replaced 1500 miles ago.
21. - All new coolant lines and PHH / FHH. Radiator hoses replaced also. BTW, new radiator 5000 miles ago. OEM thermostat.
22. - 1 small crack on dash. The rest is perfect.
23. - 3rd row seats. I have them at home. Will be included of course.
24. - I’m willing to send more info and pics. Just ask for them.
25. - This is a Florida Truck. Not a rust bucked. The undercarriage is clean clean
26. - Upgraded Fan clutch, heavier oil. New Fan and Shroud.
27. - Upgraded sound system; Kenwood Bluetooth double din with rear view camera. It will make your butt dance. A little bit of engine sound, is common on this vehicle.
28. - 2 things REALLY RARE on these vehicles... Power Antenna works and D Light also.
29. - VEHICLE IS SOLD AS IS.
30. - You can drive it ANYWHERE with no problems. Recently did a 2000 miles trip without any issue.
31. - This truck can cruise at 85 m/h and will behave like a new one. Speedometer is in perfect shape, just 8-10 m/h down due to tires and lift.
32. - Front ARB bumper, WARN M12000 winch, 10 inch KC light bar on front and 2 round 10” LED spot LIGHTS with amber ARB INTENSITY covers. If the truck is sold for less than $16.000.00, I will keep this options.
33. - ARB extended breathers on both AXLES.
34. - Custom built Rock sliders.
35. - Double U-Joint Front Driveshaft.
36. - Rear OME adjustable Panhard.
37. - No signs of coolant in the oil / No signs of oil in the coolant.
38. - Australian “OH SH*T” grab bar on passenger side.
39. - WheaterTech Floor Mats, front and rear.
40. - I have invested more than $20k on this vehicle without the value of it.
41. - New tire rod around 5000 miles ago.
42. - KOSO Thermometer.
43. - UNIDEN CB Radio.
44. - Located in Tampa, Fl.
45. - LEXUS LX450 corner lamps.
I have an ARB roof rack and a OVERLANDER XL roof top tent. For $1400 extra both are yours ($2200 value). Ask for pics and you will receive them!
I tried to make the listing as completed as possible.
I will be more than happy to answer anything!
You can contact me at mdej3@outlook.com
Every single thing you can imagine in maintenance have been done.. Have paperwork also!
Im asking $18k. Any offer will be considered really: trades accepted but with cash on my side, preferred 80's series.
Main reason to sale is that the family is getting bigger and need a house!
She is ready to go anywhere you want to take her. Can help with shipping.
Thank you!!
Manuel R.
Thank you!!
Manuel R.
