SOLD 1993 FZJ 80 Cummins 5.9 Diesel NOW $35,000 (1 Viewer)
Year
1993
  1. 80 Series
West Glacier, Montana 59928 United States
Mileage
240142
Color
White
1993 Toyota FZJ 80 5.9 Cummins conversion (2002 24 valve), rust free, 240,142 miles on vehicle (not driven in winter & stored in enclosed building last 6 winters) This Cruiser is originally from Portland, OR.
All gauges, lights, A/C, cruise control, power windows, and power locks function properly
Compushift II transmission controller by HGM Automotive Electronics
Newly rebuilt A442F transmission with billet torque converter, only 52 miles on build (have receipt)
4 inch Iron Man suspension, coil springs, foam cell shocks, steering stabilizer, panhard rod, & much more
Longfield 30 Spline Super Set Birdfield/Axle Kit, Gun Drilled- TAX-LF30FJ80 (301720-1-KIT) by Trail- Gear. These axles are made from 4340 chromoly and have a grease zerk at the end of the stub shafts which allows grease to go into the internals. More info is available at trail-gear.com or lowrangeoffroad.com.
New fuel tank & sending unit Air Dog fuel pump/ filtration system
ARB front bumper, Warn MX6085D1 winch with remote control, Metal Tech rock sliders
(5) Mickey Thompson MTZP3 LT315/70R17 tires & (5) KMC XD 132 17x9 aluminum wheels (all 5 rotated)
Eezi -Awn K9 Roof Rack System, anodized & powder coated aluminum full roof rack with high lift mount, tire mount, axe mount, shovel mount, and tie down rings
New Corbeau front seats – marine grade vinyl, second & third row cloth seats in very good condition
Ironman Snorkel plug in engine block heater and switched engine pre-heater
Alpine CD player/ stereo with USB & Bluetooth, (4) Alpine speakers and (2) Memphis speakers
19 inch Vision X light bar Vision X super white xenon headlight bulbs
Weather Tech custom fit front, center, and cargo floor mats
THERE ARE MANY MORE MODIFICATIONS LISTED BELOW. I have all the receipts for the work and modifications completed after the diesel conversion which is when I purchased the Cruiser. Also included in the purchase will be extra Air Dog filters, extra ARB panhard rod (new), extra transmission speed sensor (new), (4) extra halogen headlight bulbs, and more.
I also have the following manuals which will be included with the sale of the Cruiser:
  • Diesel Adapters diesel conversion instruction manual
  • Compushift II transmission controller manual and quick install guide
  • Alpine stereo manual
  • Eezi-Awn rack and accessory manual
  • 1993 Toyota Landcruiser Owner’s Manual & Dodge Ram Cummins Turbo Diesel Owner’s Manual
  • Cummins engine parts information dataplate sheet
Vehicle is located near Polebridge, Montana and has a clear title. If you are seriously interested in saving yourself a lot of time in research, build time, and money and would like to purchase this well-built Cruiser, please call me at 406-407-0554. Thank you.
PRICE: $ 35,000 cash or bank cashier check. Please see the details listed below. Receipts included.
DateMileageDescription
11/5/16230,258Purchased 1993 Toyota Landcruiser FZJ80 with approximately 1,000 miles on 5.9 Cummins conversion as advertised by installer
At time of purchase 5.9 Cummins conversion (2002 - 24 valve with approximately 140,000 miles) had been completed by Dustin at Diesel Adapters in McMinnville, OR. Included in the conversion were an Air Dog fuel system, VP44 injection pump by Oregon Fuel Injection, custom air filter box, billet torque converter in the transmission, Compushift II transmission controller, custom wire harness, modified fuel filler neck, custom throttle linkage assembly, APPS throttle box, custom exhaust, new front hub seals, 360 performance brakes with ceramic pads, and many other modifications. An install manual from Diesel Adapters will be included with the vehicle. Cummins engine serial number: 56873176
Engine Dataplate – (Original) VIN: 3B7KF23622M215950
12/2/16230,954Installed new engine block heater cord, new air filter, new intake heater switch and relay, and new battery cable. Work by Northridge Automotive.
12/16Installed Weather Tech cargo liner
4/8/17230,966Drained engine oil and refilled with 15w-40, installed new Fleetguard oil filter
4/15/17230,976Drained transfer case oil and refilled with Amsoil 75w90 synthetic. Drained differentials and refilled with Amsoil 75w140 synthetic.
5/2017Installed new Weather Tech first and second row floor liners
6/1/17231,062Installed new IRON MAN lift system which includes: 4 inch performance coil springs for the front and rear, (4) Foam Cell Pro shocks, Foam Cell Pro steering damper, front adjustable ARB panhard rod, rear adjustable panhard rod, front extended sway bar brackets, rear extended sway bar mounts, front extended brake hose, and caster plate kit. Installed new SLEE OFFROAD 2 inch front bumpstop drop pucks, rear bumpstop drop blocks, and ARB differential breather kit. Installed new Trail Gear gun drilled Longfield 30 spline super set Birdfield axle kit, packed the knuckles and joints, resealed the timing cover and leaking vent. Installed a new fuel level sending unit, Metal Tech rock sliders, new Carquest starter, and drained & refilled the transmission with Valvoline Max Life ATF synthetic fluid. Installed new VISION X 19” LED off-road light bar, tube clamps, locking security bolts, wiring, and relay. Work by Northridge Automotive.
6/26/17231,076Performed 4 wheel alignment. Work by Tire Rama.
7/5/17231,597Installed new Rain-X windshield wipers
7/2017Installed Eezi-Awn K9 Roof Rack System and Hi-Lift jack mount. Shovel mount axe mount, and tie downs were never installed but are included. Tire mount was used briefly and is not currently installed but is included.
9/20/17232,207Installed new engine control module (computer) due to original going bad. Work by Northwest Truck Repair.
9/25/17232,401Installed new Air Dog fuel filter FF100-2 and water separator WS100. Work by Northwest Truck Repair.
10/27/17232,856Installed new Iron Man front adjustable panhard rod that had been on backorder, resealed transmission pan, removed parking brake & adjusted, repaired leaking power steering hose under radiator, rerouted heater hose below turbo, replaced spliced fuel line, cleaned out sunroof drains, and inspected newly installed suspension system. Work by Northridge Automotive.
10/30/17232,856Installed new freeze plug in engine block. Work by Northridge Automotive.
11/26/17232,873Installed new horn
3/7/18232,873Installed new hood lift supports
3/13/18232,873Installed new rear hatch lift supports & new Rain-X rear wiper blade
4/1/18232,873Drained engine oil, refilled with Chevron 15w40 Syn blend, installed K&N HP 4003 filter
4/5/18232,873Installed (2) new hood insulation clips
4/17/18232,873Installed drain hose on engine vent pipe
4/28/18232,873Installed new engine oil filler cap
5/15/18232,918Set valve clearance to spec, flushed cooling system, greased front axles and drivelines. Work by Glacier West Repair.
5/23/18232,937New windshield and gasket installed by Glass Doctor
5/23/18232,950Installed new (5) MICKEY THOMPSON BAJA MTZ P3 LT 315/70R17 tires on 17X9 KMC XD132 aluminum wheels (all 5 have been in rotation) Work by Discount Tire
6/2/18232,952Purchased rust free rear hatch & delivered to OHS Body Shop. All hardware and trim was removed, hatch was sandblasted, primed, and painted to match stock color. All hardware and trim was re-installed on the new hatch.
232,952New gasket and rear (heated) glass installed in rear hatch by Glass Doctor
232,952New Cummins emblems and 24 Valve emblems installed by OHS Body Shop
6/7/18232,958AC recharged by Northridge Automotive
6/27/18233,060Drained differentials and refilled with Valvoline Synpower 75w-140 gear oil. Installed new crush washers on drain plugs.
7/23/18233,370Installed new Denso starter, new evaporator & expansion valve, new front differential pinion seal, and new receiver hitch to frame mounting bolts. Evacuated & recharged A/C. Work by Northridge Automotive.
8/30/18234,414Installed new CORBEAU front seats, double locking sliders, and seat mounts.
10/5/18235,191Installed new Toyota FUEL TANK and gaskets due to seam leak on original tank.
4/18/19235,766Drained engine oil, refilled with Delo 15w-40 & installed new K&N oil filter HP 4003, and installed new air filter Wix 46272
4/24/19235,766Rotated all (5) tires
4/26/19235,766Lubed front axle shafts, driveshafts, and steering knuckles
5/2/19235,780Installed (2) new Toyota u-joints on rear driveshaft and drained transfer case, refilled with AMS OIL 75w-140.Work by Northridge Automotive.
5/4/19235,836Installed new Air Dog water separator WS100 and fuel filter FF100-2. Drained differentials and refilled with AMS OIL 75w-140. Installed new crush washers on drain plugs.
5/20/19236,410Performed transmission fluid exchange with synthetic ATF. Performed coolant exchange with extended life coolant. Work by Speedy Lube.
6/13/19236,602Recharged A/C system, checked for leaks, none found. Work by Northridge
8/7/19Installed new ALPINE CD PLAYER with USB and BLUETOOTH, (4) new ALPINE SPEAKERS, and (2) new MEMPHIS speakers. Work by Marty’s Car Audio.
8/8/19237,932Installed (4) new VISION X SUPER WHITE headlight bulbs, (2) 55 watt & (2) 65 watt.
10/3/19238,956Lubed front axle shafts and rotated all (5) tires
10/21/19238,975Installed new VSS speed sensor & rerouted wiring to relieve strain on connections. Work by Northridge Automotive.
7/1/20239,134Evacuated and recharged A/C system. Installed new Air Dog fuel filter FF100-2 and water separator WS100
8/21/20239,296Drained engine oil and refilled with Chevron 15w-40 Syn Blend & installed new K&N oil filter HP4003. Installed new air filter WIX 46272
10/6/20239,537Installed new TOYOTA FUEL TANK due to rock lodged against tank creating a small hole. Work by Northridge Automotive.
6/16/21239,750Installed new fuel tank breather hose and hose clamps
6/24/21239,898Installed new IRONMAN SNORKEL. All metal exposed by installation was sealed. Work by Northridge Automotive.
9/16/21240,072Installed new TOYOTA under hood insulation and clips, installed new vacuum pump seals, flushed cooler, repaired hose boost leak at intercooler, and flushed power steering fluid. Work by Northridge Automotive.
10/28/21240,072Toyota transmission removed and shipped to Brown’s Auto Service in Billings, MT. Transmission was completely rebuilt and billet torque converter was rebuilt. Transmission was provided with a 3 year/ 36,000 mile warranty. Transmission was reinstalled by Northridge Automotive.
The snow is off the roads and they dried out a few days ago so I got her out and went for a little drive. Started right up and ran great after sitting all winter. It was great to cruise a bit again! Great time of year to go for a spin.
This looks ready for the long haul. Wish it was in my budget. Hope it sells soon, so I can stop coming back to this post and dreaming. GLWS
I have had many people contact me about my Cruiser but they are not good about responding when I reach out. Any ideas?
NEW LOWER PRICE $35,000
Saw it on Craigslist this week, sure is an awesome rig, hopefully it stays in MT.
If I wasn't dealing with teenagers and in need of something that gets better than the 12mpg my 40 gets I'd be seriously considering this rig.
Can't go wrong with a Cummins.
I love the Cummins swap. It really woke up the "Bruiser" and is better than the original motor for fuel economy also! Thanks for the compliment.
why not a 12-valve?
They are both great but in stock form the 24 valve is a little quieter, less vibration, better airflow, better coolant flow, better exhaust flow, and a little better stock turbo. The 24 valve is also easier to tune due to the electronics if a person wants to do that. Mine is stock. It happened to be what I found for sale as the engine conversion was completed when I bought the Cruiser so I purchased it and it has performed well. I am not going to bad mouth the 12 valve as it is also a great choice but that was not available to me and I am happy with how this conversion has turned out.
The Cummins "Bruiser" will be headed to NY. Thanks for being such a great seller Chad, your detailed records, patience answering all my questions and your knowledge of this turbo diesel build sealed the deal. Can't wait to get this one to get wrenching on. Good thing I have my totaled "Mean Joe Green" as a great parts truck to pull from.
Stay Tuned Mud....
Stay Tuned Mud....
It has been good to deal with you also Casey. It will be hard to see it go but I am glad that Bruiser will be going to a good home where it will be loved and appreciated. I hope you enjoy it as much as I have.
