torfab
Supporting Vendor
The build thread starts, I'm putting a 6.5 liter turbo diesel and 4L80E automatic transmission from a 1995 GMC Sierra into a 1992 Landcruiser. A few considerations are:
mounting position of the engine: The Land Cruiser 3FE is mounted off-center to the drivers side. This is to clear the driveline and keep it straight to the front axle. Not all LC engines are mounted this way, for example the 2H is slanted with the front section centered and rear off-center.
I will have to mount the front centered, and rear off-center like the 2H because the Diesel engine is much wider than the 3FE and will hit the steering box "etc" if I don't.
Gas pedal: The 6.5 is drive-by-wire, meaning I will have to salvage the gas pedal from the GMC Sierra.
Brakes: The vacuum pump on the 6.5 is sufficient to power the LC Booster, but if the pump breaks you lose brakes... When I got the 6.5, the pump was broken so that made me nervous. I have decided to use the GM Hydraboost brakes instead. I will need to modify the hydraboost master cylinder to fit the 80 series.
Adapter from auto tranny to 80 TC: I got this from Marks adapters in Australia, which allows you to keep the original drivelines and puts the TC in the stock location.
Engine mounts: I don't like buying the flat flange engine mounts, they seem weak to me. I'm making triangulated mounts out of 3/16" steel, and utilizing the stock enclosed GM mounts.
Fuel pump: I'm keeping the in-tank pump, but will use a regulator to reduce pressure.
Mounting: Several things need to happen to get the engine in place, removing the passenger shock mount, relocating the brake lines, relocating the fuel lines, and cutting off lots of brackets are in order (pics attached).
The build is already underway, but I will update as I go along
