1991 LC rear carrier bearing size
Wisconsin
i ordered arb rd153 locker and i was told to watch for carrier bearing
so i m looking at installation instruction and it talks about two different sizes 45 mm and 50 mm , so is there way to know what size i have without opening it ?
anyone have any experience with 1991 LC and rd 153 locker
text from installation manual
3.2 Installing the Carrier Bearings
NOTE:
If you are installing an Air Locker into an earlier model Toyota with a 45mm differential carrier bearing inside diameter then you will need to use the higher rated later model 50mm bearings:
Timken # 32010X-32010X
ARB # 160116
If your OE carrier bearings have an ID of 50mm, replace them with new bearings of the same type.
installation manual
PAGE # 11
