SOLD 1991 HDJ81 RHD Turbo Diesel Land Cruiser 159K miles -- $29K -- (1 Viewer)
Year
1991
  1. 80 Series
Mileage
159000
Color
Black
Decided to part ways with this incredibly rad truck due to some changing priorities.
Additional photos here
* 1991 Toyota Land cruiser HDJ81 VX Limited Trim (W/ OEM Coolbox)
* 1HDT 4.2L TURBO DIESEL
* RIGHTHAND DRIVE
* 256k KM - ~159K miles
* Fresh fluid change (oil, oil filter, & fuel filter)
* Gets great fuel mileage - typically averages 17mpg
* Fully functioning heat and a/c
Exterior - Black
Interior - blue cloth with no rips/stains
Drivetrain/Engine
* OEM center diff/transfer case locker
* ARB rear air locker
* Powerstop brake kit (rotors/pads)
* OEM Toyota drive belts
* Upgraded aluminum radiator & clutch fan
* Recent (Late 2019) batteries
* Straight piped exhaust
* ARB single air compressor mounted in engine bay w/air tank
Exterior
* (5) 17" Method wheels with 35" BFG Ko2s with 80+% tread left
* 4x4 Labs front and rear bumpers with dual rear swingouts + highlift jack mount, dual jerry can holder & axe/shovel mount and ladder
* Brand new Warn Evo 10S synthetic winch
* Whiteknuckle offroad rock sliders
* Safari snorkel
* Prinsu roof rack
* (2) Baja Designs LP9s
* Ceramic tint on whole truck
* Roof was wrapped in white vinyl for better heat dissipation
* Brand new OEM glass headlights with new crystal turn signals & corner lights
* $5K in paint/body work - both lower rocker panels were replaced and 3/4 of the truck was repainted after it entered the US
Suspension
* Slee caster correction plates
* OME nitro sport shocks
* OME heavy duty springs
* Sway bar bushing set
* Extended SS brake lines
* Leading arm bushings
* Delta rear panhard bar correction bracket
* Including BNIB Dobinsons C97-144VT front springs (I was planning on revamping the suspension and never got around to buying anything else)
Interior
* Delta ashtray usb port delete kits
* Rago Fabrication molle panels (Top shelf + both side panels)
* Fully upgraded stereo - $3500 in receipts - Memphis Sub in competition grade box, Alpine headunit with infinite features, door speakers, & tweeters - Sounds INCREDIBLE
* Viper 2 way alarm with remote start
* Momo steering wheel
Known issues;
* Cracked dashboard + bezel trim around the gauge cluster
* Remote start does not function 100% (will start, shut the truck off, restart, shut the truck off) - Haven't looked into this
* Side bolster on the driver's seat has been worn a bit flat from use
* Some surface rust underneath the truck - Primarily on the axles from what I can assess
* Truck does have some pinstriping from being off-road. I would rate the exterior a 7/10 and I am pretty OCD
* Passenger side (US drivers) sideview mirror retract motor/gearing is not functioning 100%. It will partially retract the mirror and then stopout. Seems like there are some broken gears in the mechanism
I have a huge envelope full of receipts from parts/work done on the vehicle. Clean blue title is in-hand & currently registered/insured in the state of Texas.
Truck is in great shape - I would not hesitate to drive this thing anywhere in the country.
Thanks for looking!
Please msg me here on Mud, or txt
9 7 2 9 2 1 9 3 0 8
Tyler
blown away by this rig - sadly, about 5k over my budget. lol....gl
