Why not? I had one on my 4runner and liked it... Who makes a better one with a built in hitch and spare tire carrier / gas can carrier?
Thanks
Everybody
Slee, Metal Tech, and 4X4Labs
Thanks
No ABS, weak brakes, etc.!!
There is a difference between a poorly designed brake system and a 16 year old neglected brake system.
Calipers should be rebuilt, rotors replaced, all soft lines replaced, rear brakes rebuilt and adjusted correctly, LSPV adjusted, sytem flushed and refilled, vacuum system cleaned out and old lines replaced.
I also found that when I replaced the EGR valve and EGR regulator with new my brakes worked much better.
The 3FE has an issue with the EFI relay wiring. Due to the heat of the manifold the insulation becomes brittle and can become intermittant. People say the wiring is undersized, but according to my measurements it's fine. The EFI relay contacts can become corroded and add to the woe and strife.
There is an oil galley plug that can come loose by the #5 plug. This is more common on the FJ62, but that may be an age factor.
Replace the fusible links off the positive battery terminal.
Replace the pre-filter on the fuel pump.
Replace the fan clutch.
As with any used vehicle you'll need to "baseline" it by addressing each system individually over time.
How long do trannys last? How long is a piece of string?
Have a look at the fluid first. That will give you a good indication of the maintenance history.
Are they really that underpowered? My 4runner weighed the same and had less power
Cappy, why do you keep saying your 4Runner is as heavy as the 91? Is this true?
CappyKD;
Of course, I'm some what biased, since I own the 94-FZJ80 with the super charger mod. At ur elevation the power of the FZJ engine will be quite a bit more than the 3FE engine. If u go with the 91or the 94, u will need to do brake mods; i.e., DBA rotors and FJ100 pads for the 94 - it really helps.
I've really never used the lockers much, but when u need them, its a big help. Check to be sure they work if u buy the 94.
Keep in mind that u can put the SC on the 94, if u can find one.
The 94 does not have air bags or the electronics.
The 91 will/may have a FE relay wiring problem:
http://www.safari4x4.com.au/80scool/tech/efi_relay.html
http://www.lcool.org/technical/80_series/80_series_technical.html
Having driven both 80 series I would go with the 94 for long range thinking.
Hmmmm what to do...
Buy neither and wait another 2 months for this gas price crunch to keep squeezing these prices down.
Jeez, a 91 asking 5K? I'd sell you my modified 91 for 6500!
Being in socal most of the crusiers will be really clean, when I was looking a year ago I saw alot of cruisers that were clean but had no maintainence records. Now when I did find one that had all the records, lockers and cloth interior(important to me) I looked it over and bought it for 5500..didn't even drive it.... now it was a private party 94 with 220k on the clock but everything was tight and the PO had all the records and had paid a shop to do everything including a birf job 6months prior. 90k difference in mileage if well maintained is nothing... several here have 300+k on will maintained cruisers...
always plan on spending 1k on parts (maintence) once I get a new used vehicle to make it perfect.
There was a comment above about waiting a few months, I agree with that keep looking and wait for what you want, with the housing market falling and gas prices more cruisers will be for sale. Dont get in a hurry because it fits your budget. I took several months of looking on and off. Most of us keep our cruisers 10+ years and starting with the best one you can get will help in the long run. It will also save you some work...
Personally I like the 93-94 cruisers for no airbags, factory lockers, better brakes, full floater rear, bus transmission and OBD-I computer-1fz .. and if you can get one without leather they are even better.....
good luck...
BTW once you buy join socal80's
I'm going to drive them both today, but I'm still torn....
You may not be so torn after you drive them.
;p
