Krondor
I just finished up my hood respray and wanted to let others know how easy it was.
This was my first spray job so there were some mistakes involved. If I could mention only one piece of advice: PREP IS EVERYTHING!!!
Seriously. Spend an extra day sanding. Even if everything feels smooth. As soon as you start applying paint, you will see every imperfection.
Anyways, Here is what I started with: a 1991 toyota Land Cruiser in Medium Red Pearl with a faded and pealing hood.
The clear coat started to fail and the paint was faded on the hood and tops of the fenders.
Initial sanding and color test.
I started off sanding everything with 800 grit to remove the old clear. Initially I was hoping to save the paint and only have to clear over the top. I quickly found out how thin the paint layer was once I sanded past the clear and through the paint to bare steel...
I then taped off the hood and fenders and sanded with 400 grit, feathering out any old clear to the paint. Looking back at this, I wish I would have used some 240 grit to really remove the old clear and feather then move up to 400 to finish everything off.
Painting was next. I used three cans of 3H4 medium red pearl from:
Another learning experience: 3 cans barely covered the hood. I should have purchased 5 to allow me to also paint the cowl along with a final top coat over the hood.
Next up, The clear. Wow! That made things pop!
I used 4 cans of 2K spray max clear coat.
It a really cool product that you press a button on the bottom of the can to release the 2 part clear. Then shake the can and spray. It is a much heaver duty clear than standard rustoleum or 1 part clear.
Final Reveal:
Not bad for a few days work.
Cost:
400 and 800 grit sand paper: $20
3 Cans of paint: $60
4 cans of spray max 2K: $70
Paper and tape: $20
Time: 3 afternoons. (could be done in a day if you have the whole time.
Exact Match Car Paint Made Easy | AutomotiveTouchup
Restore your car's original paint with automotive paint that's an exact match for your car's color. Our touch-up paint is high quality to deliver professional results to every paint job. at AutomotiveTouchup
www.automotivetouchup.com
2K Clear coat - SprayMax
www.spraymax.com
Final Reveal:
Cost:
Paper and tape: $20
