tucker74
Moderator
Yep - gotta rotate and remove the pressure plate bolts, then the flywheel from center. Wont need to remove bellhousing if just doing clutch
The clutch and flywheel have to come out before the bellhousing can be removed.
That’s pretty normal wear for an old flywheel. I think it’s caused by extreme heating cycles for extended period of time. Mine looked like about like that. I had a machine shop turn it down just a bit. Everything was fine once the surface was refreshed and any weight lost to the plate is negligible imo.
Second replacement. Terrain Tamer clutch kits are awesome if you are considering
Honger if you get in a bind the 91 frame donor 80 I just got in Dubai to save the turbo diesel RHD to LHD 81 has a 3F engine it I'm petty sure. Shipping would be dear, but keep it in mind as a backup.Good input...
Given that new flywheels aren't available and that I'd likely have to source a used 2F or 3FE flywheel, I think I'm going to take this in to a machine shop for turning and see how it comes out.
Good input...
I would replace it if you don’t know how old it is. It’s such a simple part and easy to do and it’s RIGHT there. You’d hate it if in two months it was leaking after you button it all together.Was going to replace the rear main while I was in here... but it looks so dry and we’ll set... almost hate to disturb it.
Nevermind... FSM shows split bearings but the high and low gears have a bushing pressed into them... now that I’ve pressed it apart it’s clear.Hey, @cruiseroutfit or anyone else in the know... should the Cruiser Outfitters transfer case rebuild kit have the split bearings for high and low gear on the rear output shaft?
I would absolutely replace that rear main. You are right there and it doesn’t get easier unless the engine is out. You don’t want to pull it all out again to redo it.
get OEM Toyota.
