grayfj62turd
I am having electrical issues with my windows. The rear drivers side window will not operate at all. I removed the motor and tested it - the mechanism works fine.
The master switch is not functioning correctly. From left to right the first switch operates the rear passenger window. the RR window switch on the door panel operates correctly. On the master, the second switch from the left controls the drivers window. The third form the left controls the front passenger window. The switch on the FR door panel works correctly, The auto down does not operate nor does the regular up or down. This switch is dead.
I now have a LR window that has opened about 4 inches from the top from my testing of the motor. I can not get the window to move back up. Kinda like to keep her a bit dry when it rains so is temporary solution exist to get the windows rolled up and then how do I begin to address the window master switch issues.
ADD: I found the the green box relay in the front left door was UNPLUGGED. When I reconnected the relay, none of the windows would work. Hmmm, maybe a bad relay?
Thanks for any help!
