Looking for some insights to figure this fuel leak out.
Problem: Visible fuel leak coming from the right rear passenger panel- when driving you can smell fuel in cabin and around the rig. Also you can see fuel dripping fast on full tank, slower on 1/2 and almost nothing on 1/4 tank. Fuel leaks out rear passenger panel- and also can see on the right rear mud flap.
History: I am the third owner, FO- had vehicle for 28 yrs and tons of service history. Sold in 2016 to PO at 109K miles. PO owner drive less than 4K miles in 4 yrs. Car today as 113K original miles and is in tip top shape excluding the fuel leak. Tons of documented service history/maintenance accessible
Upon searching the service history: 1992 fuel tank recall performed. No issues.
2011- the FO broke down, ran out of fuel and towed into Toyota dealership. At this time they performed the following: Fuel pump replaced, fuel pump bracket replaced and flexible fuel line replaced.
2012-2016. Every time the rig was in a Toyota shop the FO complained of a fuel leak/smell in the cabin of the rig. Each record shows that the Toyota mechanic checked for visible leaks and smell and states could not find any.
PO- was told all of this and was of the opinion that it was just a FJ62 thing???
Trouble shooting thus far: Replaced gas cap with another OEM gas cap. Did not work.
Help? since the fuel pump change- the rig has obviously had some sort of fuel leak
thanks in advance for your input
