1988 smog pump delete (1 Viewer)
Plano texas
Hi, Jim sells the pulley for the smog delete On the fj60 series. Who sells one for the fj62 series? Thanks, Mike
going from memory as to how the belts are run,
could you delete the smog pump and run the belt, crank - PS pump - WP??
Thanks, Have not looked into that ,will look tomorrow. Still snowing up there? Mike
we had flurries last week, several inches up in the mountains
We are hitting 90....with Tornadoes. Mike
Jim, Have you got a part number?
Seems like one is too long and one is too short.
This if from the Fj62 Desmog Thread. That thread should have all the info you need.
Dorman 090-099 plug m26x1.5 is the plug for the exhaust manifold. need 1
Toyota 90340-14001 plug for the air rail. need 4
Dayco 22528 is the belt. need 1
Dorman Help 02254 cap is for the intake. need 1
Dorman 555-118 expansion plug instead of an egr block off plate. need 1 check the specs
High temp thread sealant
1/8 inch or 3.5mm vacuum plugs. need 7
Delete your cats anyway you want.
Did a little research tonight because I’m bored and figured I’d try to keep the confusion down a bit. I personally have not tried all of these. I am going off of my experience and others with the short belts ~53” and @Old Nick belt pictured on the previous page ~59”. The first 2 bypass the alt and the second 2 do not. The Dayco 22590 is the only belt listed that I’ve never seen used but it will be the next belt I buy. FWIW.
Gates tr22525
53.06 outside circumference
.625 top width
Dayco 22528
53.39 outside circumference
.69 top width
Gates tr22588
59.375 outside circumference
.625 top width
Dayco 22590
59.64 outside circumference
.69 top width
Check this out.
