- Thread starter
- #81
Finished wiring in the second battery. I'd like to try get the starter battery as clean. I also need to add a switch for the winch.
Think the FrontRunner Ladder is stout enough to mount things to? Like a small propane tank or a hi-lift?I definitely would not mount anything to the ladder. It's a very thin plate that they use behind the license plate light. I think it'll be fine as a simple handhold to make accessing the roof easier though. Frontrunners ladder seems more sturdy to be honest.
What's the capacity of that? Did you add a transfer pump to transfer to the main tank?Here's a couple pics of the Long Range Automotive fuel tank installed above the driveshaft. Still need to try weld up a basic exhaust to replace the piece that was chopped off.
A small propane tank would probably be okay on the lower part. The top part of the troopy door seems too flimsy to support anything.Think the FrontRunner Ladder is stout enough to mount things to? Like a small propane tank or a hi-lift?
forum.ih8mud.com
It's the transmission that pops out. Usually from 1st or 2nd into neutral. H55 gearbox.Just go be clear it's the t-case popping from L to N? Or are you saying the trans will pop into neutral while in low range?
T-case is common on high mileage/worn cases. It's a combination of worn sleeve, fork, shaft, gear, spring. The spring can be shimmed as detailed by @Irish11
Oh man that is a whole different can of worms I think. There are a few H55/Toyota experts on here that I am sure have good input. @orangefj45 and @OGBeno come to mind. They among others are the brain trust haha.It's the transmission that pops out. Usually from 1st or 2nd into neutral. H55 gearbox.
T case stays in gear properly. This is also under heavy load and steep, bumpy trails.
Luckily it's not critical enough yet to be a huge worry. Still drives and shifts perfectly fine.Oh man that is a whole different can of worms I think. There are a few H55/Toyota experts on here that I am sure have good input. @orangefj45 and @OGBeno come to mind. They among others are the brain trust haha.
