Hi, What are the replacement options ? Mine is dead and the cruiser won't hardly start . Wife getting impatient. Thanks, Mike
Where did you source the oes version of this switch? Can you provide a link?Found them from oes. Even has Toyota stamp on them. Mike
Correct, I believe it tells the cold start injector to fire when the temp is below 59 degrees.Glad to see this thread. Im in the same boat. Out of curiosity how/when does this system work? Cold start as in first start of the day or as in <50deg or none of the above??
Thanks, yeah I did see that. It just would have been nice to find a plug and play option without having to find a later style terminal as well and splice wires.A later sender works; just need to get the right connector from a later harness
Post in the Wanted section, good used connector housings can be found here on MUD, and the wires/terminals can be easily removed and switched over to replacement housings. I've done a lot of switching over on my '71 FJ40 build - no need to splice wires.Thanks, yeah I did see that. It just would have been nice to find a plug and play option without having to find a later style terminal as well and splice wires.
I didn't think about switching the pins! Great idea. I need to invest in some little picks for those jobs.Post in the Wanted section, good used connector housings can be found here on MUD, and the wires/terminals can be easily removed and switched over to replacement housings. I've done a lot of switching over on my '71 FJ40 build - no need to splice wires.
