Build 1987 LJ70 frame swap + mods build thread
No air going to nor from the pump. Doesn't start any better. So, I started going through the glow system. I have replaced the timer with two manual buttons, one for each relay. I also found out that the round relay was broken, so I replaced it with a starter relay off a lawn tractor. This hasn't helped much. If I hold the round relay after it's started it stops sputtering, but the square relay has no noticeable effect and it doesn't start any better. The voltage at the glow plugs is way off though. With the battery at 12.0v and the round relay active I get about 7.5 - 8v at the glow plugs, and with the square relay active I get 1.5 - 2v. I'm also unsure which one is the preheat and which one is the afterglow. Troubleshooting continues tomorrow.
I would say the square relay is you’re after glow. With after glow setup you need the proper glow plugs.
I'd imagine the glow plugs are of the proper type since I haven't replaced them.
Today I tried to skip the square relay completely and held the round relay while starting, and it started right up. Not even any smoke. I'm happy with that performance, but I'd imagine it's not great for the longevity of the glow plugs.
I tested different glow plugs once and it’s surprising how fast the wrong ones will come apart. The proper slow glow ones will take full voltage for only about 3seconds or so, any longer and they go Kaput.
I have held them at the higher voltage for close to 30 seconds and with the engine running, so either some previous owner has replaced them with the wrong type, or the still unidentified voltage drop to 8v is enough to keep them alive.
I have not done any troubleshooting today since it had started raining once I got home and the garage is occupied by the Triumph.
This begs the question, should I continue to try to fix the problem to get both modes working, risking both burning out the plugs if I preheat for more than 3 seconds and not getting adequate performance from the afterglow if it's the wrong glow plugs, or should I just keep using the single mode for as long as it works?
The third option would be to completely overhaul the system and get the automatic system working properly, but I don't really have the time or money for that right now, and I also quite like the manual buttons.
The Land Cruiser has gotten a (most likely) fuel problem, which is discussed in this thread. This is kind of a problem, since the Land Cruiser has been my daily while doing some maintenance to the Triumph. I have to get to school somehow, so I put the Triumph back together halfway maintained.
The rocker cover gasket broke when I removed it, a new one is only available from England, and there is no thick enough gasket sheet available, so I made one from an electrical cable. Cut to length, join with a piece of metal wire and silicone in place. Somehow it doesn't leak at all.
The plan was to put the brand new winter tyres on today too, but when I picked them up from the tyre shop they had discovered a bulge in the sidewall. I'm not scared to use it until I get a new one on warranty, but I don't know yet if the vendor will want the damaged one back. Hopefully they'll answer my email tomorrow, as it's supposed to be below freezing on friday morning.
Tomorrow working on the Land Cruiser continues with cleaning the filter screen in the pump.
Are you planning to have a differential lock in the rear axle, and where are you thinking of buying it?
I have been considering it, but after experiencing the amount of articulation it has I don't really feel the need anymore. I still might in the future when I'm rich, but I will replace the axles with UAZ portal axles before. For the Toyota axles, I had found the same Chinese HF Differential air locker that costs 700€ on 4x4parts.fi for 250€ with free shipping on Alibaba.
