For Sale 1987 FJ60 Silver AZ rust free $27,500.00
1987 FJ60 Toyota Land Cruiser, silver $27,500.00 OBO
For Sale a rust free Arizona 1987 FJ60 with original paint located in Flagstaff AZ. Clear title in hand. This Land Cruiser has had a ton of work done recently. It has been a daily driver for a couple of years now.
This 60 series is a perfect candidate for a Overland build, It has everything you need and nothing you don’t. Very original with nothing cut up and hacked on. This cruiser is a treat to drive and is extremely reliable. No expense was spared rebuilding the engine, 5 speed transmission and t-case rebuild. This cruiser is solid and needs very little done to be adventure ready.
Work done to date
All parts installed are factory Toyota parts where posable, any non available Toyota part was substituted with the highest quality parts available.
1 Full original engine rebuild, including new short block, crankshaft, camshaft, pushrods, lifters, oil sending gauge, pistons, connecting rods, rod bearings, rings, main bearings, oil pump, oil pan, new distributor cap, new spark plug wires(Bosch), motor mounts, tranny mounts, new clutch hydraulics (Asin), new clutch, pressure plate, throw out bearing, pilot bearing.(154,000)
2 Old Man Emu suspension. 2.5 inch medium in front superheavy duty in back nitro charger shocks anti inversion shackles. (160,000)
3 ARB air compressor (160,000)
4 Ammo can center console (160,000)
5 New alternator and starter (both Bosch) (170,000
6 New brake master cylinder (Aisin) (168,000)
7 New h55f tranny, shift lever, shift knob,fully rebuilt transfer case bearings, bushings,seals, boots, and shafts including gears. 8 New clutch, pressure plate, pilot bearing previous only had 20k, new gear oil (174,500)
9 Choke cable assembly (150,000)
10 Engine cooling fan (150,000)
11 Carb cooling fan (160,00)
12 Front window regulators (SOR) (168,000)
13 New Goodyear Armortracs (159,000)
14 New coolant hoses total of 8 (150,000)
15 Head job including valve job new head gasket (152,000)
16 New fuel pump (Kyosan) 173,00)
17 30k service battery service, brake bleed, clutch hydraulic bleed, air filter, fuel filter, spark plugs (NGK), power steering flush, new gear oil in both diffs and tranny/transfer case, repacked front wheel bearings, greased drivelines, tire rotation, rear drum service, and valve adjustment.
18 Oil changes done every 4K they have been done early rather than late. Only using Toyota D3 filter and new drain washer and Castrol 5w-30 conventional. Driveline greased during every oil change.
I also have itemized receipts in hand that list all gaskets and seals etc.
Full disclosure :
-front wiper wash spray motor does not work
-rear diff makes noise at high speeds when deceleration, needs rebuild
-trip meter does not work
Contact info = Gabe 928-432-5648 or Seth 928-606-3867 in Flagstaff AZ
Body
I really dig the creative photography - awesome shots- nice work!
You do certainly seem to be asking a premium for this truck - I'm sure all current owners are hoping you get it! :)
Good luck with the sale!
thank you, thought I would do something different. Thanks for the kind words :)
Seth
