1987 fj60 needs sensai info!
Hi, I have installed a new 6 in 1 header and new 32/36 weber carb but may have vaccum problems :bang:. Have fuel and spark but it won't start unless I spray fuel into carb. It doesn't seem to be sucking the fuel down and by the way I started to desmog. Any suggestions on the weber install and/or timing, vaccum issues? No smog in N. Idaho.
Thanks, Shawvdog :beer:
1987 FJ60, 31" BFgoodyear mud terrains, Moclocs, header,weber, almost desmogged.
Pictures before and after header/weber install
For starters I removed that big brass nipple you have in the riser plate and plugged it with a big set screw when I ran the Weber.
Just curious if you installed the fuel line nipple in the left side yourself. Mine went in the right and i'm just curious if the orifice is blocked as you say you are getting no fuel. :hhmm:
Thanks Joe, I did have that plugged at first then added the nipple. I'll plug it back up again. My fuel does come in on the left. Can you tell me what the small nipple on the back of the carb goes to? :confused: Here's a pic, I have it plugged w/hose and screw as a temp.
Thanks again, Shawvdog
My first question always seems to be: Why the Weber? General consensus seems to be they cause more headaches than they cure.
Now that you already have it, what do you mean by "not sucking fuel down"? As in, it's not spraying out of the jets when you pump it? Does it have a bowl that you can see fill up? Where are you getting fuel at?
