So none of the patch panels I have seen will cover that corner you are talking about. You are better to get someone to cut a panel for you.
I ended up custom making mine using the other side (which was good) as a template. Then I welded it in place.
For the rear I built my own inner skin to fix the issue of the the missing piece. Once done I bonded and sealed the whole thing.
Seam sealer using a calking gun for the interior and there are some good writeup for the drip rails
That link should help you.
Rain Gutter seam and drip rail reseal
I had been planning on re-sealing the gutters and drip rail someday as some areas were cracked and causing light rust on the underside painted area of the gutter near the doors. One day a couple weeks ago, I was walking by my truck and got curious and started picking at the original seam...
forum.ih8mud.com
