anyone have vacuum diagrams for this.. i cant seem to find them anywhere. mine has a bad idle surge at 1500 rpms, tried a new carb and still the same, idle will also hang at 2k rpms when really hot
i dont hear a click when it happens..the rpms just drop and come right back up only at 1500-1600 rpms if i hold it there it does this...also if cruising down the road at the same pedal position it will do it as wellDo you hear a click from the area around your carb when you cycle the ignition from off to on (not actually starting the engine)? That sounds like the idle control solenoid isn’t working.
sweet thank you!!!!!
I have one for sale!Where does one get a new carb for US spec FJ60?
Walmart, $9.99Where does one get a new carb for US spec FJ60?
