1985 Toyota Truck FS
Discussion in 'Other Vehicles' started by larc68, Feb 22, 2009.
  1. larc68
    larc68
    42
    Aug 6, 2007
    Some changes at work are forcing me to sell the truck. Below are the specs and please don’t hesitate to email me with any questions you may have.
    This is a turn key rock crawler.
    85 4x4 pickup regular cab
    22re with 167k
    5 speed
    new fuel injectors
    coolant thermo switch
    new cold start injector
    red top optima
    header
    new exhaust (including cat)
    new fuel pump
    new radiator
    new TPS
    The timing chain and clutch have been replaced as well.
    **Also included is a complete compete AC setup that can be used for AC or onboard air.
    Drivetrain:
    Inchworm dual cases.
    BudBuilt crossmember.
    Heavy duty lo spline front driveshaft
    Axles:
    Front- factory 85 with 5.29 gears and Aussie locker, 27 spline Longfield axle shafts.
    Rear- IFS rear housing (3” wider and larger brakes), diff armor 5.29 gears with a full Detroit locker (not a ratchet style so no clicking).
    Suspension:
    Front- rear springs with Bilstein shocks.
    Rear- 63" chevys w/3 inch blocks with Bilstein shocks, ubolt flip kit.
    **The suspension is nice and flexy and doesn’t sit too high even with the 35s.
    Tires/wheels:
    15x10 aluminum rims with 35x12.5 MTRS. Two spares included.
    Brakes.
    Front- they have been upgraded to the V6 calipers and master cylinder.
    Rear- stock brakes
    Body:
    The bed is a tube bed that the previous owner started but didn’t finish. The welds are ok, they could use some cleaning up though. Aluminum tool box in the bed also included. Sliders.
    Sliding rear window.
    Interior:
    Corolla seats, newer carpet, map light, tachometer.
    SPARE PARTS: yes there’s a lot...
    2 complete set of birfs with one extra ball too
    I have a spare block and head that goes with the truck
    3 intake manifolds
    A few starters
    A few alternators
    Extra rear spring hangers
    Diff armor
    An extra rear driveshaft
    Spare front shaft
    Extra driveshaft flanges
    Extra CV for driveshaft
    60" high lift
    Extra power steering pump and reservoir
    Extra throttle bodies
    Misc sensor, injectors, fuel pump
    Extra AFM
    Extra poly bushings for the rear springs
    Ill stop there but I know I have a few more odds and ends
    Areas that need some attention:
    Rear spring hangers need the bushings replaced. they are included, I just didn’t get around to it .
    The rear diff leaks from the bottom. not a lot but you get some drops.
    The input tranny seal. a 2 dollar seal that everyone overlooks when they change the clutch.
    The truck is hard to start in cold weather, that’s why I replaced the cold start injector and sensor. It will start but it cranks a while. I think its fuel pressure related. Once it starts, its fine.
    Every once in a while the CEL comes on but goes right back off.
    The truck passed inspection with no problems but I never had to have an emission test done. All the emissions stuff is still hooked up so I don’t see why it wouldn’t pass.
    This picture I have is older. The pics does not show the real blocks installed so thats why it may look a little saggy in the rear end. The front flares have been taken off, but still have them, and the rear fender also have been taken off, but still have them also. I will get more recent pics up asap.
    Truck and extra parts, $4200.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. nanuk
    nanuk
    333
    Media:
    1
    Albums:
    2
    Mar 17, 2002
    Colorado
    This is about what I am looking for, but location would be a key factor. Let me know where it is.
  3. larc68
    larc68
    42
    Aug 6, 2007
    Unfortunately Im in Virginia.
  4. larc68
    larc68
    42
    Aug 6, 2007
    back up
  5. larc68
    larc68
    42
    Aug 6, 2007
    Dont be bashful, make an offer
  6. Dustins94toy
    Dustins94toy
    46
    Nov 20, 2008
    NewCastle, IN
    How about trades, 86 4runner 22re, 94 pickup???
  7. larc68
    larc68
    42
    Aug 6, 2007
    Sorry but i need to get rid of it and use the money towards a car. thanks though
  8. Mo Rocks
    Mo Rocks
    646
    1
    Aug 13, 2007
    Georgia
    That looks like an interesting truck for the price.
    Looks like there is a bit of surface rust !!
    Any thru rust on frame or body ???????
    Updated pictures would help..........
    thanks.
  9. larc68
    larc68
    42
    Aug 6, 2007
    There is some surface rust. One spot one fixed by the previous owner and im not aware of any other bad spots. As for pics, they are the latest ones I have from about a week or so ago. Are there any others you would be interested in?
  10. Mo Rocks
    Mo Rocks
    646
    1
    Aug 13, 2007
    Georgia
    How far are you from Augusta, GA 30907 ????????
  11. larc68
    larc68
    42
    Aug 6, 2007
    Sorry about the pics mixup. I had one pic when I first posted it that was old. So, the ones one here now are the latest. Sorry
    I can get you any pics you would like. Just shoot me your email and i will send them. Just give me some time to take them.
    The tcases do have the stock gears.
    The only vibrations are from the tires. They arent balanced but actually dont ride that bad. But YES, you will get a vibration from them.
    Im looking for Subaru, preferably a WRX.
    As for distance, you are about 10.5 hours from me. Im located in Northern Virgina.
    If you have any other questions, ask away.
    thanks,
    donnie
  12. larc68
    larc68
    42
    Aug 6, 2007
    back up
  13. Mo Rocks
    Mo Rocks
    646
    1
    Aug 13, 2007
    Georgia
    Sorry for the delayed reply. I have too many things going on right now !!!!!
    I am waiting to hear from the CPA to see what the IRS situation is this year.
    You have a nice truck for the price.
    I will contact you for more info if I can swing the $$ after I hear from the CPA.
    Thanks....
  14. larc68
    larc68
    42
    Aug 6, 2007
    Thats fine, I understand. I havent taken pics yet. With the little snow storm we got, its been nasty out. I will get you some!!!
  15. larc68
    larc68
    42
    Aug 6, 2007
    back up
  16. larc68
    larc68
    42
    Aug 6, 2007
    anyone
  17. MB4wd
    MB4wd
    101
    Feb 8, 2007
    Friendswood, TX
    Are you interested in a possible trade for a car? Very DD'able 94 SAAB 9000 Aero. Good on gas, plus it is a rocketship on the road. 2.3l turbo 4cyl with a 5-speed manual. It does not have TCS which it highly desired in this model. 125K on the car.
    Matt
  18. larc68
    larc68
    42
    Aug 6, 2007
    sorry but i found a car. i pick it up on wednesday.
    so with that being said, im really looking to get rid of the truck now
  19. larc68
    larc68
    42
    Aug 6, 2007
    Someone make me an offer. I need it gone since I just bought a car!!
