Builds 1985 JDM 3B Engine Rebuild and Other Stories (1 Viewer)
Status
Not open for further replies.
Anyone have a #2 bearing cap? Literally fell apart in my hand pulling it. FML. Amazing how well the engine ran like this... :lol:
This guy is really tricky...
I found that door hinge adjust wrench you got me from Toyota works real good on that. It’s an “S” shaped wrench, 12mm.
Works great on a 1PZ/1HZ/1HDT but never tried it on a 3B.
Cheers
Cheers
Yeah, I tried a S-style wrench but the 2 ribs of the bell housing are too close to the bolt. A thin-walled 6 pt socket is the only one that fits there.
Continuing with disassembly....
You can see here the rear main seal retainer (it's aluminum):
Rear main seal removed (90311-95003 is the service replacement part number):
You can see here the oil cooler cover: Again, has the Toyota and Daihatsu emblems....
Oil pan removal:
Bottom of the block where the oil strainer attaches:
3B Main bearing numbers and oil cooler
Toyota always indicates at the back of the block where it mates with the oil pan the main bearing numbers: In this case, the #1 bearing is sized "MARK 2" and the rest are sized "MARK 1". This allows you to build the engine utilizing sized bearings vs. machining the crank to go undersized by a certain amount.
Engine with the oil feed lines and strainer removed.... I clean FIPG and gaskets as I go through the disassembly process:
You can see that #2 main bearing cap gave NO indication that it was damaged. Amazing robustness of these engines....
When you are removing the coil cooler, you can't really see this stupid little allen bolt without really looking. Don't forget about it before prying on the aluminum housing!
Oil cooler and cover removed....
Oil cooler housing once parts are removed....
You can see here the date stamp for when Toyoda Industries cast/machined the block assembly:
Using our previous date code numbering system, this number equals: 5 9 0 B
5= 1985
9= September
0= place holder
B= 2nd manufacturing day of the month
This fits very closely with the JIT parts procurement philosophy.... The engine block was cast in September for installation into a truck that would be manufactured in the first manufacturing week of October 1985.
RH side of block cleaned:
Timing cover:
Cover removed: You have the camshaft gear (larger one to the left of the picture), the idler gear (center gear) and the timing gear (on the front of the crankshaft):
This is your gear oiler which oils the gears as they synchromesh and turn:
3B timing gear removal and oil pump casing
The timing gear has to come off to remove the oil pump case/inner timing case:
Case removed: The rear cover with the JIS screws houses the oil pump assembly:
And you can see here the oil pump drive gear and the driven gear:
3B connecting rod backlash measurement and oil squirter
The FSM states that backlash on the connecting rod on the crankshaft has to be measured before removal...
The tolerance is 0.200-0.320 mm standard. All were well within tolerance. Even if they were out, this damn motor is so robust that it probably wouldn't matter in the grand scheme of things.
You can see the oil squirter here at the bottom of the cylinder bore... There are 4 of these-- 1 for each cylinder which is great for a turbo application.
I was about to send the rocker arms to @FJ60Cam to have his machine shop address the damage to the valve interface surface, but I remembered that 3B engines were used in Toyota Industrial equipment. So, off I went to my trusty conversion book that converts Toyota engine part numbers to Toyota Industrial part numbers. The rocker arms showed as converted:
View attachment 2257870View attachment 2257871View attachment 2257872
So, I ordered them from my local Toyota Industrial/Forklifts dealer. We shall see if they arrive. I will update once I find out.
Unfortunately, Toyota Forklift called and said to "pound sand." They don't like me. :lol:
Off to find good used versions. Have some leads from Dan at 4Wheel Auto in Canada. Will report back.
Status
