Has the water to air inter cooler always been in play?
I’m stuck with that option as well I think. No way to put a front mount with huge pipes.No, Cim. Adding it now. It’s been sitting in a box since when I live in ATL...
Little parts are important too...
What would you plug into a 24v lighter socket that wouldn't fry itself? Is there a way to run the lighter plug off the new 12V circuit you're installing for accesories?
It's going to be interesting to see if your hood closes with that intercooler where it is. I have a 3BII, maybe the valve cover is taller. I don't think I have that much room between my valve cover and the hood.Put 5 gallons of diesel in and started it up... keeps cranking but won’t catch for some reason. Glow system work perfectly, glow plug relay clicks and indicates plugs are ready to start.
But man... engine just will not catch. Wants to. Primed the pump at the filter housing. Need to bleed air I’m thinking.
I’m beat. Need to sleep on it and check fuel delivery tomorrow AM.
Gotta be something stupid simple. It always is with these stupid simple engines. I’m hoping to end this thread pretty soon here.
View attachment 2351995View attachment 2351996View attachment 2351997
I've found especially if the fuel system has been totally dry, you might need to crack the injectors to get them bled properly. Also found that having someone pumping the primer whilst cranking seems to helpPut 5 gallons of diesel in and started it up... keeps cranking but won’t catch for some reason. Glow system work perfectly, glow plug relay clicks and indicates plugs are ready to start.
