- Thread starter
- #1,301
I was able to pull it out this far with my hands…
Fuuuug…
Fuuuug…
Never had a chance
Holy guacamole!!!!! Was these liner finish (ready to install piston) or semi-finish then you need to bore and hone after installation ?
Never had a chance
That suck soooo much
Is there any way to rectify this with assembly/machine shop? That’s piss poor.
What the hell! How is something like this possible?
How knows, shop may have use stone to clean the engine bore prior inserting the liner...he may felt asleep on the drill while honing? Running out of oil (low oil pressure) too much heat, piston got "stuck" with liner and force the liner to start moving just little bit and wear to a point that it got loose? They are semi-finisg liner so the shop needed to bore it, it use to have a good fitment at some time??? That's soo weird, my bloc is sitting in the garage with new liner (exactly the same)...Wow, that sucks man. The 3B series of diesel aren't hard at all to work on, thats just attention to detail BS.
My guess is,
The 3B cylinder liners are press fit. You might be able to tap them in, but you should really press them in. The same with removal. You should have to press them out. These are not loose fit liners.
Possibilities are wrong sized liners, possible the block was already bored for some reason? Possible the machine shop bored out the block as they thought is was a loose fit sleeve?
They obviously didn't use and sleeve retaining loctite paste which holds the sleeve and helps with heat transfer from block/sleeve.
Possible the liner/depth counterbore was not correct allowing the piston to move since there was no retaining paste.
A few options, but it all boils down to shoddy work from machine shop.
That's always a good day. Really looking forward to the build.
ack no power steering port ot timing case
