Builds 1985 JDM 3B Engine Rebuild and Other Stories
Colorado
And the bumper fabrication is completed and installed.
Next to mess with this tire carrier kit. I’m sure it’s going to be just as fun as the bumper was to get fit...
Once the carrier is completed, everything goes to powder.
Rear view:
LH side:
RH side:
Onur, I feel you pain on this one. I purchased this same kit for my SWB cruiser ('89 BJ-73). I knew some modifications would need to be made, but the issue with the bottom plate (frame rail) mounting points and complications from leaf springs really spins this project into a new dimension of frustration, and none of it was disclosed by the company. I have yet to begin the fabrications, but I may play around more with how to modify the bottom plates to fit to the shortened sides. I plan to mount all the rear plates, then use stenciled out cardboard for dummy side pieces and play around with things. Good work, nonetheless. It looks great and I don't suppose finding a mounting point for the side/bottom plates is totally necessary, though it would be nice!
OGBeno
www.olc4x4.com
Moderator
GOLD Star
Patagonia, Arizona, USA
The tire carrier is going to be a nightmare for fabrication because the bumper needs to be completely redone to include tail lighting.
I’ll be selling this bumper sometime next year. It’s a complete let down for what my purposes were. It will work for someone else looking for a robust rear bumper only.
cruiserdan
SupportingVendor Emeritus
Moderator
Land Cruiser Heritage Museum broom closet
KAYMAR. Case closed.
75 Series Troopy, modify brackets to suit. I'd do it again in a heartbeat. I love that bumper.
Karachi, Pakistan
Hello from Pakistan, been following this thread with great interest, sorry things didn’t work out as planned but hopefully you’ll sort it out once you are back.
If possible could you email me the engine manual. I’m thinking of getting my 3b rebuilt.
Cheers
Ali
OGBeno
www.olc4x4.com
Moderator
GOLD Star
Cheers
Ali
What type of a 3B do you have? With inline pump? With rotary pump? 3Bii engine? What platform is it in?
Anchorage, AK
Hey Beno,
Do you have the part number for the special bolt used in the tilt steering rebuild? Is it 45897-14010? Or is it 45897-12030?
Thanks
OGBeno
www.olc4x4.com
Moderator
GOLD Star
@Onur did you ever dive back into this to see what is going on? Or did I miss that somewhere?
I did.
Just an over-pressurization of the entire engine when I ran that blew out the turbo oil seals when the engine was working against the braking system.
New turbo installed and all has been good so far.... About 1000kms. Need to do a final break in oil change.
Blew out the oil in the exhaust system...
Oil pressure good at idle.
