- Thread starter
- #1,021
Bloody oily mess everywhere.
Looks from here like the exhaust manifold is dry so at least the oil isn't coming through the engineBloody oily mess everywhere.
View attachment 2371916View attachment 2371917View attachment 2371918
Where does that oil feed line come from? Right off the cooler?
is there a possible problem with the relief spring for the oil pump?
There should be one on the cooler as well if I remember correctly.
That’s a real bummer man.
I couldn’t tell you whether it’s better to break things at home, on the road, or at your destination. I’ve done all three and it literally takes the life out of you no matter what. Hang in there.
Oh yeah that was a fun one.Done all three as well Cim. Hell, we were together for the water outlet debacle in Moab a few years ago on your 80... man... that was a rough one too.
Did you put in a new oil pump rotor set? Use the old set? Check it with a feeler gauge and phase at installation?
Tossing out ideas.
Cheers
There is really not much that could cause an over pressuring of the oil system. Did your oil pressure spike on the gauge? A stuck check valve or plugged relief valve but that is super rare. Clogged filter but that doesn’t make much sense either.
So I am kind of doubting it is an over pressurized oil system. Certain catch cams can cause probs, the filter type are the worst. A proper catch can won’t cause any issues though, they are just screens or layered mesh that catches the oil vapor and allow it to form droplets which fall into the bottom of the catch can. I don’t even think you are running one though, right?
Cheers
I think he said a few pages back that the valve cover vents to the ground.
