Is dinner ready yet?
Careful there genius. You'll be rotating your own damn tires.
Or she'll rotate her own tires.
Awesome thread Beno. I love your meticulous nature. Since after we sent you the turbo kit we have changed the turbo adapter gaskets to a graphite impregnated material w/ a stainless steel wafer sandwiched in between. Incredible gasket material that was designed for the space shuttle. We have a company make them to match both the Garrett turbocharger and the Toyota 13BT manifold. These now are included with our kits but I can arrainge a set for you if you would prefer a set for the reassembly. Great well documented thread, enjoying the rebuild.
Your work seems very meticulous. You may decide to replace those rockers, but some 320 grit followed by a buffing wheel with jewelers rouge and they will probably be fine.This is quick reference sheet for the date code system.
Of course, as suspected with these old IDI engines, the pre-combustion chambers were all cracked....
And the head was cracked in between the valves as well. This could be fixed but don't feel like addressing right now.
I just did the same thing to my "made in China head" Your valves are shrouded just like mine were. I would guess that the factories in China use some of the same mold parts between different B series heads. You could bolt it together and it would run fine, but you'd be loosing some airflow. Took me about 45min with a $25 walmart die grinder to remove the extra material and smooth out the bowls and short side radius. Good luck.So, I'll be trying my hand at doing some porting and polishing as well with the extra material on the inner portion of the valve seats. I'll be posting up pictures of that once I start that process later this weekend.
New camshaft:
If you enjoy using the dremel than good on you. My first heads I started with a dremel and stopped. Went to a electric harbor freight grinder and spent several hours with that. Air die grinder is exponentially faster. The $75 harbor freight compressor works fine. Just take a 30 second break every 10 seconds you grind. You can buy a air die grinder at Walmart and a pack of stone grinding bits for less than $35. It takes 2Xstones for 1 head.....have funStarted porting and polishing this morning at 9am. Finished at 3pm. What an awful job.
Went through one Dremel tool and had to take a break and go buy another one. :rolleyes
View attachment 2260503View attachment 2260504
