- Thread starter
- #601
New fog light switch: these will power the front lights on the ARB:
New stop lamp switch:
This s*** gets more disturbing by the hour. View attachment 2315815
Next was a new combination switch/stall. Old one worked fine but the color on the positions were all gone and, well, it is a 35 year old part.
Old one goes into the bag for a rainy day:
The switch is manufactured by Tokai Rika which is an old Japanese electronics/switch company... basically anything electric that allows human-machine control and interface...They pretty much make all of the switches for Toyota
You can read about their product line here:
Waiting intensely for the head to get bolted to the block
Thouroughly enjoying your thread. My shopping cart at partsouq just grew significantly
Much of the subsequent posts are going to be new OEM parts I’ve been collecting for years now.
Many of the components you see here are basically updated part numbers from the old -90K00 nomenclature to the -60000 numeralization. This standardized and rationalized the 7x series within the -60000 Land Cruiser numbering system.
Most of the suppliers are still the same, as well.
The rear scuff plate used to be chrome metal. Not a fan. Newer 7x trucks use a nice ruggedized version.
And of course, the holes line up perfectly in the rear body member. Direct fit.
New dash reflectors:
Decided to go with a black dash bezel assy vs the color-matched version. Gives it a bit more utilitarian look. This is a direct fit and comes from later 7x trucks:
New parking brake handle cover in black:
That rear scuff plate is so much better than the chrome version. Does the end caps also come that way too?
Edit: Nevermind. I see it is one piece unlike the three piece chrome version. Quite an improvement.
The interior installation has begun. This is good stuff now. Putting a jig-saw puzzle together.
First off was the tilt steering. The swap went fine and everything was as it should be. Took a bit of wiggling, cursing to get the key cylinder in, but with a bit of pick-work, that eventually gave in too.
This little snap ring is a PITA... for the upper intermediate shaft:
it.
Had to compress the bracket onto the shaft to get the groove popped out.
This is the break-away bolt... it sheers to allow the bracket to collapse in case of an accident:
When it reaches its desired torque rating, the head of the bolt snaps off leaving a weird cone-like head.
