1985 FJ62 Overheats
Discussion in '60-Series Wagons' started by Johno, Aug 27, 2006.
  1. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    I would like some help diagnosing the problem. My 1985 FJ62 with 3F motor has recently started to overheat.
    Here is what I've done so far:
    Thermostat - Checks out OK and for now I have left it out.
    Fan Fluid Hub - This was suspect so for now it is replaced
    with a fixed hub.
    Radiator - Removed and reverse flushed - seems OK
    Engine Block - Flushed through top radiator hose to bottom hose.
    Water Pump - Disconnected top radiator hose and started engine
    most water pumped out in a few seconds.
    Head Gasket - No sign of water in oil or exiting exhaust. No
    significant amount of bubbling at radiator cap.
    Problem - Engine overheats to the point of boiling after about
    15 kilometers (10 miles)
    Any suggestions appreciated:confused:
  2. 60wag
    60wag SILVER Star
    1,927
    43
    Jun 25, 2003
    Boulder, CO
    Hmmm... you've hit all the usual suspects.
    Does the heater put out significant heat before it overheats? This would confirm that coolant is actually circulating - that there isn't a blockage somewhere.
    Is there a shrould around the fan on radiator?
    Can you measure the temp of the rad with an infrared probe? This might show cold spots in the rad indicating insufficient flow.
  3. kevinmrowland
    kevinmrowland Forum Lifer
    2,278
    Media:
    16
    Albums:
    1
    30
    Sep 2, 2005
    Eugene, OR
    Yeah, I like what he said, and do you really have a 1985 FJ62? With a 3F not a 3FE? Where are you located? Show us a pic of your truck, if it really is a 3F I would love to see a photo of the engine compartment.
    Welcome.:cheers:
  4. prairie wolf
    prairie wolf
    32
    Jun 25, 2005
    SOUTH DAKOTA
    you said you left the thermostat out for now.
    if driven without one temp would probably rise.
    thermostats hold water in radiator to cool it.
    then it gets released back into motor when cool enough.
    Are there a ton of bugs on the front of the radiator?
    Belts tight enough?
    most people know more than i do but just my thoughts.
    life is good.
  5. import silvia
    import silvia
    471
    2
    Feb 14, 2005
    Tucson
    That is a bad little myth that has long been proven false. The thermostat keeps the engine at the correct temp by only letting in enough of the cooled water to maintain the correct temp it does not hold out radiator water until it has cooled enough. If that were the case an overheating engine would never open its thermostat.
    If you are overheating while under way then you either have an airflow issue or a system cooling capacity issue (clogged radiator). Start your truck from a cold system and feel the radiator to see if it heats up uniformly or if you can feel any cool spots.
  6. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    1985 FJ62 with 3F motor overheating
    Yes it is 1985 FJ62 with 3F motor.
    In Australia 4WD's were given a bit of a delay in needing to comply
    with some emmission controls. It doesn't have catalytic converter
    or air pumps that you guys have to put up with.
    Thanks import silvia. I did reverse flush the radiator and flushed the
    engine block but I will have another go with a radiator flush product
    and see if that shifts more gunk.
    Thanks 60wag. Yes both the front and rear heaters are working. In
    fact with both heaters on full it keeps the temperature down enough
    to use so long as it isn't worked hard. The fan has a shroud. I've had
    the FJ62 since 1986 and its stock standard. I don't have an
    infrared probe but will follow up on making sure the radiator is clear.
    Somebody told me adding a pint of vinegar running it till hot and
    flushing it is as good as anything.
    Thanks for your posts.
  7. bigbrowndog
    bigbrowndog
    1,662
    16
    Apr 30, 2005
    N.Q. australia
    Did you measure the coolant in to make sure you never put less in because of an airlock, common on the 2H. Might pay to look at the pump under pressure also some of the radiator core could be blocked.Always pays to stay with toyota genuine thermostats and radiator caps. Check your timing and fuel mix as the 3F will tend to overheat if run lean same for 3FE.
    My 1990 80 series has a 3F also the 3F is in the FJ75.
    [​IMG]
    [​IMG]
  8. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    Thanks bigbrowndog,
    I run the motor and then add more water as I have had the air lock
    problem before.
    I now have a bottle of Wynnes radiator flush and will give that a go
    tomorrow morning.
    I do use genuine radiator cap (just fitted a new one) and thermostat
    although for now have left that out to aid flushing and elliminate it
    as a possible problem.
    I keep thinking it must be a head gasket problem or even a cracked
    head but I can't find any evidence that this is the case.
    :bounce2:
  9. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    Thanks BigBrownDog for the PM.
    I have now used the Wynes radiator flush but it didn't do much
    and the problem remains.
    There is no sign of any water leaks including the water pump.
    I have now once again removed the radiator and this time the
    water pump as well. No sign of any water pump problem.
    I have flushed the radiator again this time leaving it sit for a couple
    of hours filled with dilute Phosphoric Acid.
    I will refit the water pump and radiator tomorrow but don't expect
    things will be any different.
    As I said before I can't find any evidence of a problem with the
    head gasket or head but I am running out of ideas
  10. 60wag
    60wag SILVER Star
    1,927
    43
    Jun 25, 2003
    Boulder, CO
    Get the rad flow tested by a radiator shop while its out of the truck.
  11. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    Thanks 60Wag for your post and BigBrownDog for your PM.
    The engine runs fine with no noticeable reduction in power.
    It seems that my problem is the radiator. I don't have a good
    radiator repair shop near me but I have tried using several products
    to clean it out. Of those I have found a very strong industrial
    detergent did the best job. Others I tried with little effect are
    Wynnes Radiator Flush, Dilute Phosphoric Acid, Vinegar 50/50 with
    hot water, and CLR Calcium Lime Rust remover.
    Anyway what I did is with the radiator lying horizontal with the
    inlet and outlet up scour the radiator in the same way as they scour
    water supply mains. That is with compressed air and water.
    To reverse scour I connected the garden hose to the lower radiator
    outlet using a rubber bung to seal it and turned the tap on full.
    I then connected my air compressor line to the radiator drain
    connection with the compressor set to 100 PSI. This seems to scour
    out the radiator very effectively. I did this many (maybe 50) times.
    To forward scour I connected the hose to the top radiator inlet and
    applied the compressed air to the radiator overflow pipe with my
    hand held on the radiator cap inlet.
    Now having put everything back together I drove my test run to the
    end of my road and back (15 kms = 10 miles) and the temperature
    only got up to normal. Previously I would have had to stop along
    the way to avoid it boiling.
    Thanks guys for your assistance.
    One other thing. I would like to add to the things that should be
    bought from Toyota (the thermostat and radiator cap) the fan
    hub. I have recently bought an after market fan hub that was
    OK at first but failed after 2 months. It was replaced free of
    charge by another after market hub that failed straight away.
    I am now running a second hand fan hub that seems OK but not as
    good as it should be. I will get a new Toyota fan hub.
  12. bigbrowndog
    bigbrowndog
    1,662
    16
    Apr 30, 2005
    N.Q. australia
    Good to hear Johno. Good trick the compressed air , LOL bit of Tassie know how.
    Yes, the cleaners only work when it is a mild case if cores are blocked the cleaner will not go through only follow the easy path and clean that.I think the toyota fan is the only way to go also especially with a diesel the petrol motor is more forgiving.Did you pull your old toyota fan apart and check it, perhaps the oil level was low.:beer: :beer:
  13. 3F62
    3F62
    9
    1
    Jun 21, 2006
    East coast of AUSTRALIA
    Before you replace your fan hub $$$$$$, crack it open & add some silicone oil Toyota part No.08816-10001 its 18ml tube about $15 Aust made the world of difference to mine.......
    Cheers
  14. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    Thanks BigBrownDog and 3F62,
    My original fan hub has a problem with its valve driven by the
    bi-metal coil in front. I have two other fan hubs, one after market
    that I don't trust and another second hand one. I will try to get
    the silicone oil and add it to the second hand fan hub and see how
    that goes.
    Thanks for the tip
  15. bigbrowndog
    bigbrowndog
    1,662
    16
    Apr 30, 2005
    N.Q. australia
    With the one that is nackered you can stick some small bolts or self tappers in it works ok up here but may not be great in a Tassie winter. Is the spring ok on the other see if it has disconnected or has broken. If you hold a hair dryer or heat gun near but not on it you will see if it is working properly or not.
    https://forum.ih8mud.com/showthread.php?t=79661
    Some pics here. cheers.
  16. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    Thanks bigbrowndog,
    I have already put some grub screws inside the buggered fan hub.
    I ran this a few days but found the noise running at 110 kph a bit
    much. It did provide heaps of cooling though. Still without a
    thermostat I couldn't get the temp gauge to move up the scale any
    more than about the width of the needle.
    I bought a tube of the silicone oil from Toyota and added that to the
    "seems OK" fan hub and am now running that.
    The weather here in Tassie is still fairly cool (although spring is now
    here) so I will have to wait until the weather warms up and I am
    towing a heavy loaded trailer to see how the fan hub now performs.
    Thanks again for your advice.
  17. Beck's Bier
    Beck's Bier
    20
    Sep 3, 2006
    Mt. Sidney
    Something that I did for a "jig-rig" on my overheating toyota P/U was install an electric fan on the opposite side of the radiator (if you can find one that fits) with an on/off switch wire from the battery to the dash. This was just a quick fix when I was low on money and had nothing else to drive.
    Good luck anyways and I hope you dont get screwed by the radiator shop if you decide to go there.
  18. Dynosoar
    Dynosoar Slightly Disturbed SILVER Star
    3,726
    415
    Feb 4, 2006
    SoCal
    1.Water Pump
    2.Replace hoses they may be colapsing undr load (restricting flow)
    Good luck you Tasmanian Devil
    Dynosoar
  19. Johno
    Johno
    10
    Aug 27, 2006
    Tasmania, Australia
    1985 FJ62 Cooling System now OK
    Thanks everybody, my cooling system is now working properly.
    The scouring of the radiator did the trick and saved me the cost
    of a new one or at least the cost of a major radiator repair.
    A couple of tips:
    When removing the radiator.
    To avoid having to remove the air conditioner condenser use an
    angle grinder with a 1mm thick disc and cut screwdriver slots in the
    ends of the two horizontal bolts that hold the top of the radiator.
    Using a screwdiver to hold the bolt you can then with an open
    ended spanner remove the square special nuts.
    I fitted a length (about a foot) of a ladies stocking inside the top of
    the radiator held in place by the top hose. This caught an amazing
    amount of muck that no amount of flushing had got out.
    Be careful about leaving the stocking there permanently as it seems
    to act as a wick and a small amount of water seems to find its way
    out.
    Thanks again for all the advice.
  20. rpm1982
    rpm1982
    1
    Dec 20, 2011
    i have the same problem with my 1992 80 series 3F so i hope this helps me
