For Sale 1985 FJ60 Blue Springs Missouri
1985 Toyota Land Cruiser.
165,000 miles daily driver so this will change.
Asking $5,000 OBO
Located in Blue Springs Missouri.
- 2F I6 w/ Weber carb w/ holley adjustable fuel pressure reg.
- New optima red top battery.
- new GM alternator.
- new thermostat.
- new plugs, wires, cap & rotor.
- New ManAFre ceramic coated header w/ new Y pipe and block off plate.
- Factory air, compressor needs rebuild, have i ring kit.
- new stereo and speakers, 5.25 fronts, 6X9 rears.
- aftermarket front seats.
- H55f 5spd w/ ManAFre HD clutch
- factory transfercase.
- SOA w/ Alcan factory rate springs.
- HD crossover steering.
- RS9012xl adjustable shocks front hoops rear customs upper mount.
- New set of Alcan orbit eye springs not installed with mounts for SRS.
- Front knuckles cut and turned.
- Yukon 4.88s with ARB lockers front and rear.
- ARB Big compressor with tire inflation kit.
- Bobby Longs Fj80 rotors
- new rear brake shoes.
- Stainless steel braided brake lines.
- Alopro sliders
- custom 2X6 rear bump w/ receiver hitch.
- champion 10500 winch on DIY mount, have factory front bumper
- 4 each 35X12.50 General AT2 (less than 2,000 miles)
- set of 5 DIY weld on bead lock rings with anti-coning feature.
- 5th steel wheel with brand new shredded General AT2.
All suspension and drivetrain work done by PROFITT MOAB.
Runs and drives great, it is my daily driver. Have only been able to wheel it once, went to Disney OK, rig works great off-road. This vehicle has been through Moab etc, it shows, body is rough, rock rash, rust, character. All glass is good, gauges work, seat belts work, wipers, heater(s), locks and latches all work.
Needs list is pretty short
- rear main seal leaks and needs to be replaced.
- steering gear box leaks and needs to be rebuilt.
- AC compressor leaks and needs to be rebuilt.
- passenger side tail light lens and marker lenses need replacement.
- driver front corner needs to be straightened out from a fender bender.
- winch needs a new roller fairlead.
- parking brake needs to be adjusted.
- Needs a new owner that wants to go wheeling, with two young kids and we just don't get out enough.
$4,500
Hauling an empty trailer to Idaho next week. Can deliver along route for fuel.
Adam G
