Never really posted my truck or it's background so I thought I'd share...
I found a listing for this truck in Ohio but it spent most of its' life in CO. It ran when I got it but not very well. Worn out carb, vacuum leaks and screwy wiring everywhere. It had rust in the body and tailgate but the frame was pretty clean and the interior was in very good shape. This was a pic from the listing
I trailered it back to KY and decided to sort through the mechanics to see if I could get it running well. Gave it standard tune up bits of filters/plugs/wires/cap & rotor. Got a new Weber 38 and dove straight into a desmog.
I've never owned a 60 before and certainly hadn't wrenched on one, so I wasn't sure I'd ever get it running again... but alas I got it fired up a week or two later. Although there were some close calls where the throttle stuck and a fuel line popped off and it started spewing coolant like a geyser. I thought it was going to kill me. But eventually I got it dialed in. I also discovered that it had had a pretty significant engine fire at some point. It had a wiring harness that was spliced into the original and it wasn't correct so certain lights didn't work no coolant temp oil pressure gauge etc. The battery cables were toasted, the fusable link was burned, the alternator cables had melted and the engine bay paint was singed and crispy.
