- Location
- United States
1982 Toyota FJ60 Land Cruiser from California de-smogged. $1,000,000.00
19,321 on rebuilt long block install. 239321K and counting on the frame. Dream of keeping him squashed by reality.
Builds - Buster Brown-Slow maintenance, slow owner, slowing my roll way down.
Per documentation of previous owner prior to his purchase, at 220K miles the following was performed:
Rebuilt long block 2F engine with domed head installed with rebuilt Man-A-Fre H55F five speed manual transmission/transfer case. Entire driveline rebuilt to accommodate five speed conversion. New radiator, new power steering pump, new R134a A/C, rebuilt alternator, distributor, and starter. New Spector Heavy Duty 2 ½” suspension lift.
The maintenance items completed in the last year per maintenance notes and my memory are as follows:
REFRESH ITEMS COMPLETE
Front and rear axles rebuilt (new gaskets, bearings and race still in great shape, spares purchased)
Front and rear brakes all new calipers, pads, rotors, drums, soft lines, rear hard lines, emergency brake cable.
Aftermarket rims sandblasted and painted, new 33x12.50x15 tires, front sway bar added, Man-A-Fre brackets.
All new Toyota hoses, vacuum lines, and gas lines
New replacement gas tank from Toyota
New rear seat belts per recall.
Properly De-smogged the 2F inline 6 cylinder
New cap, rotor, wires, plugs
New voltage regulator on alternator
New non-USA carburetor
New exhaust with cat delete
Fluids changed in h55f transmission, transfer case, front and rear axle, radiator flush (green)
Extended Center soft brake lines installed.
Front driver hard brake line replaced.
Rear heat delete.
New intake/exhaust manifold gasket torqued to 29 ft/lb
H4 headlight upgrade (relay and heavy gauge wire)
Interior vinyl floor covering in front.
Interior door cards with custom vinyl (I like, you may not)
JVC mid line blue tooth stereo with pioneer component system, Sound Ordinance 8” powered subwoofer in Tuffy center console unit. Hands free phone!!
IN THE WORKS (not done but n the list as time permits):
Map A/C circuit to see if it is possible to tie into dash controls (rheostat under passenger dash) and A/C idle up vacuum valve on head.
Windshield squirter inoperative.
Heater core disconnected, diagnose and fix.
CB installed in dash but not hooked up.
Rear heat delete.
