Hi All! I've been poring through the years of alternator posts and have learned much about the differences between the housings (2 tab, 3 tab), pros & cons of higher amp models, etc. I'm not running anything extremely demanding and have been fine with the stock alternator to this point. I'll be adding a four tame LED pods, one in each corner, and a small bar up front but that's about it. I have a dual battery configuration so not worried about excessive draw at this time. At 267k miles it's finally time for a replacement. Has anyone used one of the ProAmp rebuilds from Tucson Alternators?
For a 1981 FJ60 would the internal regulator be at the 2:00 position or 10:00?
Recommendations are welcomed and thank you!
Select Year | Tucson Alternator
www.tucsonalternator.com
