For Sale 1981 FJ40 Intake/carb/Manifold/Accessories
This set up was removed from a running 81 FJ40 what you see is what is included. everything is really good shape.
Looking for 500 obo let me know what you think? Located in So.Cal.
nice !
do you have the small triangle bracket on the fire wall and the carburetor bracket and the rod that goes between ?
the accelerator linkage
if so please let me know
it will look like this :
Oh I do not need one I am just an educator .so many manifolds are cracked....Dave
You know I’m not 100% sure, but I think that qualifies as Dave’s first tech post! :p
He is most certainly correct too. Instead of the usual ‘some assembly required’, this is a ‘some disassembly required’ situation. Gaskets and tubes on the insulator are often suspect too.
I’d be hard-pressed to get to the nuts on the two middle studs of the head without disassembly , so chances are everything has already been separated and it won’t take more than about 30 seconds to answer the question. ;)
Reason these components were removed was to use the low mileage block for a earlier pre smog build.
