Recieved new guage cluster today. Appears closely the same but some minor differences. Not wanting to fry it off the bat, I need some hookup advice. (pics Attached).
Removed the 12 pin connector from the old cluster and on the passenger side of the guage, bottom were 2 black approx. # 12 or so guage wire connected together to the positive terminal (which is one side of the ammeter). Seemed odd to me that Toyota would go through the trouble to connect 2 wires to the same terminal, but maybe there is some reason I'm not aware of, or the previous owner didnt know what they were doing. In testing with key off or on one of the black wires when grounded to the frame shows 12.5 Volts. The other black wire, key on or off when grounded reads 0 volts. With the key on or off connecting the two black wires together with the volt meter shows 12.5 volts. Should I connect the hot side to the positive side of the new cluster and the other black wire that appears to be ground to the negative side of the guage? Any insight would be greatly appreciated
