Is there a crush washer on the oil pan drain plug? Removed it & did not see one. Should there be one on a 1979?
Many thanks for the reply. I have the 24mm plug. Will drop by Toyota tomorrow to get that washer.Yes, there should be one.
Do you have the original pan or the Toyota replacement. On the replacement pans they went with a smaller drain plug like. Original is a 24mm drain plug. I think the replacement had a 17mm
Here's a pic of the 24mm plug and gasketView attachment 2814518
