1978 transfer case in and out play on rear output shaft
twin cities
Rebuilding my solid transfer case 1978 4 speed
upon reassembly of the high and low gear and the front cone I seem to still have 1/8” of in and out play on rear drive shaft. This doesn’t seem right..,
will this play be removed with the installation of the rear housing and or perhaps a bearing isn’t seated ?
any thoughts on this?
thanks
WA, USA
Do you have the FSM? There is a clear procedure on setting the bearing preload on the t-case output shaft, sounds like you need some shims, a lot of shims of the play really is that much.
The rear bearing retainer sets the preload on the output shaft. you will have excessive play until you tighten the bolts on the speedometer housing.
