- Thread starter
- #21
Thanks.June 1966 started 44999. July1966 started 45484. I inverted 5 and 2 to come up with January 1966. FJ40 never reached 452XXX which would be six digits over 400,000
Thanks. Will look further.It should have two more digits but that frame welding destroyed them. Oct or Nov 1974 according to SOR's chart.
Land Cruiser Frame Numbers
www.sor.com
Will check later and report back. Thanks.Should be three VIN on the vehicle. One is on the frame as already pointed out. A plaque would be on the A pillar driver's side. That one would be held on with rivets. 78 would have a plaque on the firewall by the heater blower. That would be held on with rivets as well. Prior to 78 would be on the passenger fender below the battery. Can't tell if the front has a shackle reverse. If it has most likely covered the stamped frame VIN. Just seen last post. That is a January 1966 frame.
That looks to me like a v8 engine, perhaps not too badly done.
Doh. I looked at the FJ45 sheet. My apologies to the OP.June 1966 started 44999. July1966 started 45484. I inverted 5 and 2 to come up with January 1966. FJ40 never reached 452XXX which would be six digits over 400,000
Just found this. Body then a ‘78 with “artistic freedom” on other portions of the rig?Will check later and report back. Thanks.
Thanks and not sure where I go from here. I did a bit more research and the ebay seller also owns a towing and RECOVERY service. Not sure if i have any recourse through ebay or otherwise. Not sure what to do with the "Frankenstein" I own given all that i know.The tub isn't a '78, as it has the old filler neck opening...and the firewall doesn't seem like a 78 either as it has the two-part vent openings.
Kinda looks like someone did a bit of title-washing there, putting the 78 VIN plate on the door and calling it that rig, even though I don't think there's a single bit of '78 on it other than that plate.
5 years is a bit of time...but I wouldn't want to be that ebay seller trying to explain that away...
Not familiar with them, but sounds like i should avoid them. Thanks.that Work smells of he who’s name I shall not say..
vintage off road
Now it sounds like this vehicle may not even be sellable. Is there even a market for this? Thanks.Well, that certainly throws a new wrinkle into the what's it worth...
www.sor.com
