1978 FJ 40 driver and passenger door window removal (1 Viewer)
Chapel Hill, North Carolina
How do you remove the window glass! I unscrewed the window from the bottom track and then pushed the glass up but can’t get out of the track....what is the trick to get it out?
Thanks!
keith
I believe you have to remove the glass run channel in the door as well, 1 bolt below latch mechanism. Then you can tilt the glass forward and lift it up to remove
