I was cleaning up my water pump while I have the engine out/working on my truck build. I noticed evidence of scale/leak at the weep hole so I figured it was time for a replacement. I ordered a new Aisin WPT-063 which as I understand is the equivalent to Toyota OEM. (Technically, I know Toyota stopped offering the OEM Water Pump with fan clutch and no oil cooler -- but Aisin made the original Toyota pumps so that is why I am calling it OEM).
Side by side the pumps look similar enough, minus the "plugged" port in the casting originally designed for the oil cooler on the new pump.
On the original pump "TEQ" is cast into the aluminum below the top arrow, and "AISIN" is cast above the bottom arrow/black line. (hard to see above the black line, I know. . . but trust me its there)
On the new pump those two areas are ground down so nothing legible is in the casting. A little "Aisin" sticker is stuck on just to the left of the top arrow/ground off area.
Is this how the new Aisin pumps are made/delivered? I can understand why the "TEQ" would be ground off a pump sold under the brand name, but I do not know why the "AISIN" casting would be ground off at the bottom . . . ? The little sticker is nice, but any generic pump can be branded with a sticker.
Perhaps I am overthinking things -- the pump matches up in fitment and will bolt up to the engine just fine. I guess I just want to make sure I am getting the genuine pump I paid for.
Anyone else finding the same thing when acquiring a new water pump?
